my fisrt jae 21fe
  • Doug Smock
    • 5264
    Originally posted by martin View Post
    Re cg position on JAE hydros, i spoke with Rod Geraghty one of the designers of the JAE team about this very subject. I was fitting a larger motor & esc which altered the cg position. He said the JAE design boats were very forgiving on cg position & it would be fine. Martin.
    That is true to a point however, if you go too far forward you'll find that the boat will be darty. Stay as close to 60/40 as you can.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • siberianhusky
      • Dec 2009
      • 2184
      I found my Jae 12 to be sort of picky about cg, it ran with the cg wrong but ran much better once I figured out my mistake.
      CG was too far forwards and the rear end hopped, just enough to be annoying, at first thought it was the ski design. Then went over everything again and found the problem.
      Thing flat out flies now and tracks like a slotcar.
      • martin
        • 2869
        Obviously where not talking moving cg foward to much, in my case it was around 5/8". Martin.
        • Matias777
          • 19
          Hi mate if you just want to have fun what you got its fine use 3s1p 4000mah or more at least 45c and octura x440 shoud get you 50+mph and no problems you can upgrade later if you want to race.
          • Serpents811
            • Oct 2011
            • 381
            it looks by the feedbacks that im getting with this setup i should be hitting 60+ pushing close to 40,000rpm and a 1450 prop
