I have several folks putting speedmaster struts on their spartans and other hulls and wanting wire drives for them. I have made some but do not remember the length the speed master needs. I thought they simply had a brass bushing in them. Any idea on the length of shaft...2-3/4?
Speedmaster strut shafts?
Tags: None
Jeff, The stanard ones are 2", the extended length are 2.5"
TGTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Jeff,
I recently got a SPD strut for my JS. It was configured so that the entire .250 stuffing tube went all the way from the nose to the rear of the strut; then the 3/16" id bushing went inside. This would make angle adjustments problematic so I cut the stuffing tube so that it just entered the nose @ 3/16 . Then made another .250 piece to fit inside the rest of the length of the strut and put in the 3/6" bushing. Now it's easy to "wiggle" the strut angle-wise. Not sure if this applies to your situation but I thought I'd chime in.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Thanks.... Just seems like I had to make them longer for someone. Actually with 1" out for the prop end seems 1.25" may not be enough inside the strut. So Seems I was thinking around 2.75" was better.
Jeff, here's a SPD short strut.
The strut bushing and the longer stinger bushing
DSC02878.JPG DSC02879.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Jeff,
Ideally the stub shaft would be as long as the SM bushing for maximum support, this is around 2".
TylerTyler Garrard
