Speedmaster strut shafts?
  • Jeff Wohlt
    • 2740
    I have several folks putting speedmaster struts on their spartans and other hulls and wanting wire drives for them. I have made some but do not remember the length the speed master needs. I thought they simply had a brass bushing in them. Any idea on the length of shaft...2-3/4?
    www.rcraceboat.com
    jwohlt5362@yahoo.com
  • BrianW
    Rocket City Racing
    • Aug 2011
    • 100
    Jeff,
    The standard .187 Speedmaster strut is 2" long
    • RaceMechaniX
      • 3024
      Jeff, The stanard ones are 2", the extended length are 2.5"
      TG
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        Jeff,
        I recently got a SPD strut for my JS. It was configured so that the entire .250 stuffing tube went all the way from the nose to the rear of the strut; then the 3/16" id bushing went inside. This would make angle adjustments problematic so I cut the stuffing tube so that it just entered the nose @ 3/16 . Then made another .250 piece to fit inside the rest of the length of the strut and put in the 3/6" bushing. Now it's easy to "wiggle" the strut angle-wise. Not sure if this applies to your situation but I thought I'd chime in.
        • Jeff Wohlt
          • 2740
          Thanks.... Just seems like I had to make them longer for someone. Actually with 1" out for the prop end seems 1.25" may not be enough inside the strut. So Seems I was thinking around 2.75" was better.
          www.rcraceboat.com
          • properchopper
            • 7708
            Jeff, here's a SPD short strut.
            The strut bushing and the longer stinger bushing
            • RaceMechaniX
              • 3024
              Jeff,
              Ideally the stub shaft would be as long as the SM bushing for maximum support, this is around 2".
              Tyler
              Tyler Garrard
