Fighter Cat 3-16s 200a ESC and CC2028 has any body used this combination successfully
  • mikem1234
    • Aug 2011
    • 21
    Make-a-Wake the props are X470 cut down to 55mm.
    6BOOST Can the 2028's handle 12s?
      • 5554
      Not according to the Castle specs..............30k max
        • 5554
        Originally posted by 6BOOST View Post
        Although if you ran it on 12s you'd have 8500a capability.
        6BOOST
        Not quite sure what that means?
        • mikem1234
          • Aug 2011
          • 21
          So knowing where I'm starting with the props do you think I should get the bigger controllers?
          • mikem1234
            • Aug 2011
            • 21
            [QUOTE=Make-a-Wake;384832]Not quite sure what that means?[/QUOTE
            me either
              • 5554
              70mm props cut down to 55mm will actually "act" like 60mm's +/-. I would not go more than 10s though. Props seem fine for a twin.
              • mikem1234
                • Aug 2011
                • 21
                I'm going to start with 9s and if all goes well I'll do 10s. I sure do wish I went with the 300a though!!! Might just buy a couple but I'll have to run it by the queen...
                • 6BOOST
                  • Sep 2011
                  • 286
                  44v x 200a = 8800w, that's continuous watts, the controller is capable of double that for surge watts. Even on 10s is capable of 7400a continuous. Now I know we don't run an esc at 100%, but we also don't run it at 8kw continuous either, the amount of time you'd actually see over 8000w would be minimal. I'm not saying a 300 wouldn't be better, but I also think Ben's 200 would go close to handling it. Anyways......
                  As far as 12s goes, the motor is rated to 30k, at 750kv we get 33krpm, I would be highly surprised if it had issues, I will let you know in the next few months just how many rpm's it takes to kill one
                  6BOOST
                  6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
                    • 5554
                    Well...............you had written 8500a...(amps)........in post #15, thats what threw me off. The motor is 780 kv not 750, and i have logged mine pulling 8500+ watts on 10s running 100% throttle.
                    Here's my 47" putting out 8000+ watts...............fastest pass is at 0:40
                    • 6BOOST
                      • Sep 2011
                      • 286
                      I have watched your video's many times, it was one of the reasons I purchased some 2028's And sorry for the confusion on a/w, my bad.
                      It might be worth asking Benjamin if the 300a speedy is the same unit with an extra cooling block, I have both and the 300 is the exact same size but just had a second cooling block. If it is he can sell you the second block and some new heat shrink. Not saying it def is, but worth asking the question.
                      6BOOST
                      • mikem1234
                        • Aug 2011
                        • 21
                        I E-mailed Ben "Is your 300a 3-16s controller the same as your 200a 3-16s with extra cooling?"
                        His reply was "And updated pcb with more copper for the extra capacity."
                          • 5554
                          How much is the 300a 16s?
                          • 6BOOST
                            • Sep 2011
                            • 286
                            Retail is $288, I get a small discount having purchased quite a lot of stuff from Ben but I think you still get a small discount off that if you are a FC ember, someone else may be able to tell you the amount if any? I also asked Ben about the 200 and he said it will take 300 but run hotter and you'd have to watch the temps a lot more running at this power level, optimally a 300 would be best but doable on a 200 if you HAD to.
                            6BOOST
                              • 5554
                              Hate to keep askin' but im not a "member" so whats the price on the 200a?
                              • 6BOOST
                                • Sep 2011
                                • 286
                                It's the same price as retail but my discount is much bigger as a member on it, you'd have to ask someone else to have a look at their cost. The 200 will be discontinued when current stock runs out and it will only be the 300 available.
                                6BOOST
