Fighter Cat 3-16s 200a ESC and CC2028 has any body used this combination successfully
  • mikem1234
    • Aug 2011
    • 21
    Fighter Cat 3-16s 200a ESC and CC2028 Motor has any body used this combination successfully?
    Thanks
    Mike
  • 6BOOST
    • Sep 2011
    • 286
    I haven't used it on a 2028 yet but have used the esc before with good results, what do you need to know?
    6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
    • mikem1234
      • Aug 2011
      • 21
      Just curious of the the best timing and pwm. Motor starts very rough on 3s and gets better the more voltage I use. At 9s it runs fairly smooth but still some cogging on start up and when triggering the throttle.
      I have read a couple threads of guys using them in Baja's (seen a video too) and they're having a hard time on start up as well resulting in smoke.
      • 6BOOST
        • Sep 2011
        • 286
        What settings are you currently using? FC recommends setting timing to the number of poles, not D or Y wind like most. I used 5 degrees and 8khz for the motor I ran it on.
        6BOOST
        • mikem1234
          • Aug 2011
          • 21
          It seems to run smoother the more timing I put to it, but have left it at 10, 8khz, hard accel, log curve.
          • carlcisneros
            • Jan 2010
            • 1237
            try it on 5deggrees timing, keep it at 8khz, soft accel. and linear throttle.
            That is how I have mine set up on smaller motors and it works like a charm.
            dont forget to callibrate the throttle first before programming the ESC.
            • RaceMechaniX
              • 3024
              I ran the the 16S 300A FCR speedo with a 2028, settings were 12 deg Advance, linear throttle, 8kHz. I ran mine on 8S and 10S. The low voltage is not helping anything. Try at least 6S if not 8S.
              TG
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
              • mikem1234
                • Aug 2011
                • 21
                I think I have found about the best settings . 20deg, 16khz, hard accel and logarithmical curve. But this is only on the bench on 9s. Still has a bit of cogging when triggering the throttle but starts smooth. Guess I won't know till spring when I get it wet.
                Thanks Guys
                Mike
                • RaceMechaniX
                  • 3024
                  Mike, That is pretty high timing when you add load to the motor. I would back it off when the boat goes in the water and up the timing a degree or two per run and check the temps.
                  TG
                  Tyler Garrard
                  • mikem1234
                    • Aug 2011
                    • 21
                    Hey TG, I was moving up in increments of 5 with the timing so your probably right. I should back it down to 10 and work up from there when I get it in the water.
                    I popped one of my ESC's (Ben replaced both with the newer version) on 9s do to the coggong on start up just with a couple pulls of the throttle, so I want to make sure I do all I can to prevent this from happening again.
                    Thanks
                    Mike
                    • Make-a-Wake
                      FE Rules!
                      • 6057
                      I'd be worried about running a 200a ESC with a 2028................ I have logged over 200a consistently with both my 2028 setups.
                      • mikem1234
                        • Aug 2011
                        • 21
                        Make-a-Wake...I was wondering that as well. I should have done more research before I purchased. This will be a twin set up. Still think I will need bigger ESC'S.
                        Mike
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          Twin motor setups tend to draw less amperage due to sharing the load..................they could work if you dont overprop.
                          • 6BOOST
                            • Sep 2011
                            • 286
                            If its going to be a twin setup, it obviously hasnt been in a boat then, so why don't you see of Ben will swap it for the 16/300?
                            6BOOST
                            • 6BOOST
                              • Sep 2011
                              • 286
                              Although if you ran it on 12s you'd have 8500a capability.
                              6BOOST
