Bending Pushrod
  • Mattwarner
    • Aug 2011
    • 495
    Bending Pushrod
    Any tips for bending the pushrod, I dont want to snap it so thought id ask before i clamp it in a vice and get the mole-grips on it!
  • AlanN
    • Mar 2008
    • 334
    Use the vice and good pliers. If the wire you are using is music wire (high carbon), it has quite a bit of spring to it. Be cautious and wear eye protection.
    • siberianhusky
      • Dec 2009
      • 2206
      http://www3.towerhobbies.com/cgi-bin...?&I=LXL785&P=8
      I made something similar to this, drilled 2 holes in a piece of steel and JB welded pieces of a broken drill bit shank in. Decided afterwards I shouldn't have glued one pin, could have drilled more holes. Mine will work with a 4-40 pushrod max because I glued the pins so close together.
      • Rumdog
        • 6667
        If it's 4-40, just bend it. Use your hands, abd a vise if you have one. I've yet to break one, but I'm sure it's possible.
        • longballlumber
          • 3417
          These wire benders from Du-Bro are great little tools... Make sure you get the right size for your wire diameter...
          Later,
          Mike Ball
          • Mattwarner
            • Aug 2011
            • 495
            That's awesome! Bit pricey just to bend two bits of wire but I like having tools for every occasion so I may just splash out
            • AlanN
              • Mar 2008
              • 334
              I would bet that he's bending soft temper wire and not music wire with that tool.
              • longballlumber
                • 3417
                Alan's right...
                Provider of specialized hardware, accessories, and maintenance tools designed for the radio-control hobby industry. Wide range of components, including propeller balancers, landing gear, fasteners, and fuel system parts suitable for planes, cars, and boats.
                "Note: Do not attempt to bend hardened wire (music wire) with this tool."
                • pescador
                  • 503
                  For making the z-bends for a servo these pliers are great.
                  http://www.hobbyking.com/hobbyking/s...idProduct=6283
                  Namba District 16
                  1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
                  • Steven Vaccaro
                    Administrator
                    • 8932
                    Originally posted by longballlumber View Post
                    Alan's right...
                    Anyone know whats being used for the hardened wire?
                    Steven Vaccaro
                    • JIM MARCUM
                      • Jun 2011
                      • 775
                      With FE boats, I use stainless steel wire VS music wire. Both can be easily bent using a micro torch until red hot, then bend with needle nosed pliers. The wire will be softer, but will work fine for most FE applications. If you need stiffer wire - as in a HUGE rudder - just heat it to red hot at the bend and quench it in oil. I have a Z bend tool, but I love to play with fire. JIM
                      JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
