How to stop capillary action on stuffing tube?? Water in Hull
  • Drax21
    • Jul 2011
    • 1077
    Originally posted by rabosi View Post
    Is it normal for a stinger to have that big of a gap? I have a regular strut on mine so it's flush against the transom. I would think that you should be able to adjust it instead of filling. I would wait till someone with more experience chimes in.
    I have flush struts on my cat but on both my Mono's I am able to adjust the whole angle of the strut thus the gap. I don't get the capillary action on the cat but both the Mono's get it so I'm guessing this is the reason. I have filled one with a flexible silicone, which should allow me to adjust the angle anyway.
    • carlcisneros
      • Jan 2010
      • 1237
      filling that small gap with silicon works wonders.
      I have been using that trick on all my stingered monos now for over 8 years
      and have not had any water enter upthe flex shaft. ( either nitor of FE powered hulls.)
      • Drax21
        • Jul 2011
        • 1077
        Thanks for letting me know, 8 years of dry Mono's sounds good! Look forward to running them on the lake and coming back dry inside.
        • BHChieftain
          Fast Electric Addict
          • 2051
          +1 on using silicon between the stinger bracket and the transom
          Here's what I did on my son's Triton mono:
          http://forums.offshoreelectrics.com/...c-to-standard)
          Chief
          • 785boats
            Wet Track Racing
            • 3423
            I use a short piece of soft silicone tubing that fits tightly into the stinger & over the stuffing tube. A car muffler extension from the LHS works well.
            Here's a pic with the piece in the stinger ready for installation & the rest of the extension sitting on the trim tab. The second pic is with the stinger all bolted up. Different Boat, but you get the idea.
            But since yours is already assembled the Silicone sealer would be the easiest option. I only offer this suggestion as an option for your next build.
            • Drax21
              • Jul 2011
              • 1077
              I caught on to the next build bit at the end, so there will be another hmmmm Good idea too with the silicone tubing etc, looks a lot neater than my silicon bodge job but still I have had no water in the hull since filling bottom and top parts where the strut/stinger meets the Hull.
              • Insaniac
                • 496
                Pick up some soft plastic vacuum caps from the auto parts store and punch a hole in the end a little smaller than the flex cable. Slide the cap over the flex and onto the end of the stuffing tube. You can use a tie-wrap on the stuffing tube to hold it in place.
                Support US hobby suppliers
                • carlcisneros
                  • Jan 2010
                  • 1237
                  that is an excellent idea to use.
                  also keeps the stinger very adjustable to boot.
                  • JIM MARCUM
                    • Jun 2011
                    • 775
                    This is a GREAT thread!!! I'm building an Avenger Pro & a Mean Machine & have ordered 3 different types of stinger drives (they're fairly cheap) to see what works best. But I didn't have a clue about how to hook them up to the stuffing tube. Thanks everyone for some great ideas. You saved me a lot trouble & wasted time, not to mention keeping my cats dry & the electronics alive.
                    Geez, I love OSE!!! JIM
                    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                    • Drax21
                      • Jul 2011
                      • 1077
                      True that. The first thing I do before I even start on a boat is tell everyone on OSE and ask for Tips. My boats wouldn't be what they are without the help of the OSE members
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2752
                        Just something I've learned with heat shrink..... There IS a difference. Use the HIGH TEMP (125°C). It holds up incredibly well. Some of my boats have the same heat shrink after 20+ runs with no signs of splitting and no water entry.
                        • Drax21
                          • Jul 2011
                          • 1077
                          I have found that since the top and bottom part at the back and the hull has been filled with silicon, I have no need for the heat shrink, no water enters but it does work as a good extension of my stuffing tube anyway
