Fast Electric Main Forum
Genesis on 10S not fast enough
3
Mtwinste
Jul 2011
09-27-2011, 06:16 PM
Well I spent a bunch of $ to run 80mph on 10S and only hit 62.5.
Using a X442. 10S. Leopard 1200kv 4082. 240amp ESC.
What gives?
Rumdog
Mar 2009
09-27-2011, 06:18 PM
The 442. That's what gives.
Mtwinste
Jul 2011
09-27-2011, 06:51 PM
I have a X445, M445, X642 on hand. Would any of those be better?
oscarel
Dec 2009
09-27-2011, 07:01 PM
Do you have a way of measuring the current you're pulling?
Mtwinste
Jul 2011
09-27-2011, 07:31 PM
I don't.
oscarel
Dec 2009
09-27-2011, 07:37 PM
The only way to know then is to start moving up in size on the prop, run for a min and bring it in and check temps. I also just saw
this
Mtwinste
Jul 2011
09-27-2011, 08:01 PM
X or M series?
4 pitch or 6?
Skullcracken
May 2010
09-27-2011, 08:13 PM
Originally posted by
Mtwinste
View Post
What gives?
Yah man, starving with that X442, I used an X445 on 6s and hit your speeds. You need an X447 or X450 at least.
Make-a-Wake
Nov 2009
09-27-2011, 11:54 PM
I'd try the m445 first........
NEED PARALLEL CONNECTORS??
QUALITY
5.5MM, 8MM,
8 AND 10 AWG,
GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight
jcald2000
May 2008
09-28-2011, 06:52 AM
Get an Eagletree before you burn the whole boat down!
oscarel
Dec 2009
09-28-2011, 07:16 AM
jcald2000
View Post
Exactly. The $80 you spend will help save that $300 esc.
Rumdog
Mar 2009
09-28-2011, 08:02 AM
You dont need an eagle tree. Prop up,, check temps. The x442 is nothing with that setup. All the props you listed are safe, however that is a LOT of rpms. Short runs. A couple passes, then check temps.
martin
Aug 2010
09-28-2011, 08:07 AM
As been said that prop is to small, The setup you have calcs to 62- 65mph.
TheShaughnessy
Mar 2011
09-28-2011, 11:49 PM
martin
View Post
I got 77 with the calculator using 44000 for the rpm. Prop needs to be well balanced at that rpm
martin
Aug 2010
09-29-2011, 04:54 AM
If you mean the OSE calculater i dont use that, My calcs were 62-65mph. Actual speed acheived was 62.5mph.
3
