Well I was excited about running on 6S but no gotty. 48mph. With a M445 prop. The boat ran 47 on 5S. Not sure what to do. I'll post up a Vid.
Genesis questions. Not fast enough.
What motor???NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I'd try an x442 on 6s.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I dont think you will hit 60 with a 4074. The x442 should let it rev out and get you low 50's...............a 4082 1500kv turning a prop in the 47-50mm range should get you real close to 60.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
x445 is the X series........with a tongue, 1.4 pitch(1st number) and 45mm dia.(last 2 numbers)NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
well, i'm thinking now that if i go up in motor i may as well go up in ESC and try to run high 60's low 70's. what will that take?
What lipo cell count would i need to run in the 70's? and should i run in series or parallel b/c that determines how much the boat will weigh. right now i've got two 5S packs in the boat and it's pretty dang heavy that could be part of my problem on the speeds.
A member on here ran a 4082 Leopard on 9s and hit 90+ mph in a Genesis i'm pretty sure...........or some cat in that size range.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Here's his 4082 1500kv 85mph Genesis.........................he hit 90+ with another Cat
