Genesis questions. Not fast enough.
  • Mtwinste
    • Jul 2011
    • 140
    Well I was excited about running on 6S but no gotty. 48mph. With a M445 prop. The boat ran 47 on 5S. Not sure what to do. I'll post up a Vid.
  • Make-a-Wake
    FE Rules!
    • 6057
    What motor???
    • Mtwinste
      • Jul 2011
      • 140
      leopard 4074-1800kv
      Gens Ace 6S2P 5300mah 30C
      180a seaking
      M445 will post video soon taking forever upload
      • Mtwinste
        • Jul 2011
        • 140
        • Make-a-Wake
          FE Rules!
          • 6057
          I'd try an x442 on 6s.
          • Mtwinste
            • Jul 2011
            • 140
            will do
            • Mtwinste
              • Jul 2011
              • 140
              is that the right motor for this boat on 6S? i was hoping for 60 out of this thing. not sure what to do to get there without upgrading ESC to 240a
              • Make-a-Wake
                FE Rules!
                • 6057
                I dont think you will hit 60 with a 4074. The x442 should let it rev out and get you low 50's...............a 4082 1500kv turning a prop in the 47-50mm range should get you real close to 60.
                • Mtwinste
                  • Jul 2011
                  • 140
                  How can I tell the millimeter from Octura prop names? Is X445 44.5mm?
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    x445 is the X series........with a tongue, 1.4 pitch(1st number) and 45mm dia.(last 2 numbers)
                    • Mtwinste
                      • Jul 2011
                      • 140
                      well, i'm thinking now that if i go up in motor i may as well go up in ESC and try to run high 60's low 70's. what will that take?
                      What lipo cell count would i need to run in the 70's? and should i run in series or parallel b/c that determines how much the boat will weigh. right now i've got two 5S packs in the boat and it's pretty dang heavy that could be part of my problem on the speeds.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        A member on here ran a 4082 Leopard on 9s and hit 90+ mph in a Genesis i'm pretty sure...........or some cat in that size range.
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          Here's his 4082 1500kv 85mph Genesis.........................he hit 90+ with another Cat
                          • Mtwinste
                            • Jul 2011
                            • 140
                            To run 9S do I combine a 5S and 4S in series? The boat will hold two 5S and 2 4S at same time for 9S in parrallel but would weigh about 10 pounds!
                            • Mtwinste
                              • Jul 2011
                              • 140
                              3.7V x 10 cells x 1500kv is 55,500 RPM!!! That seems like too much???
                              seems like on 10S i'd want to go down to about a 1,200KV?
