Ok, so my parts arrived for the apache and...
-how close should I mount the struts? -if I plan on using max. 65mm props is 70mm enough between struts? -so how close can props be to each other?
And rudder depht, I really want to mount it on the center ,but that forces the struts more apart(135mm between them .
if I do mount the rudder above them, then it´s is only about 30mm under the hull. If I mount it under the struts the rudder ends about 110mm under the hull and that is quite a lot I think.
Is the best option to offset the rudder(looks ugly that way but...)
few pics, any thoughts?
