56" Performance International Fountain Power Plant
    • 9481
    and I'm betting a 5692 on 10s could do the same
    • keithbradley
      • 3671
      Originally posted by b.mcdaniel.2009 View Post
      I thought about a Leopard 5692 1040kv on 10s2p W/ Castle 240HV esc
      I don't see any chance of this Brad. You are going to need a good sized prop to get that boat to run well and the 5692 isnt going to spin it that fast. I think I maxed out the 1090kv 5692 on 8s... in a smaller boat... with a prop that was probably even a little on the small side for the hull.
      These big monos are a whole different animal. They have so much more mass and create so much more drag. You need a good sized prop just to lift it out of the water and reduce drag. Running a smaller prop wont neccesarily lower current draw like it does with smaller boats. Generally you could go with a smaller prop and higher RPM, but with the large hulls that will start to work against you and you will just end up with a higher current draw and a slower, poor performing boat.
      I would go with AT LEAST a 2028 (and I would make the assumption that they are capable of doing more work than the 5692...anything is possible, but I think thats a pretty easy and resonable assumption). Plan on running a bit lower RPM and a larger prop.
      If you want to use a 5692, bring a twin brother along with it. You're going to need it to go 55mph. I know 55mph is nothing in smaller boats, but it will take a TON of power to get that hull going that fast. I think big monos are the coolest thing out there, but plan on your lipos being raped and your chargers staying busy!
      Got any pics of her yet?
      www.keithbradleyboats.com
        • 9481
        I agree about the rpms on a hull this size with the right prop dia..
        What about a 5692 730kv on 10s, that should get it done
        • b.mcdaniel.2009
          • 1872
          I agree keith, I love the large mono's...Just watching the gasser's on you-tube running in the ocean or along real boats is getting me excited
          Here's one Keith or check out my wtb thread were Steve V. posted it.
          ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
          • b.mcdaniel.2009
            • 1872
            +1.
              • 9481
              Hey throw some youtube vids up if you want, your getting me all jacked up now and wanting to sell some of my smaller boats to build one of this biggies
              • crrcboatz
                • Jan 2009
                • 1103
                Well said. I know the difference between a 260 modded zenoah and a 28.5 modded zenoah in this size hull is a buttload
                • b.mcdaniel.2009
                  • 1872
                  here we go.....
                  Last vid to be is the best...That hull looks sick flying on flat water
                  • b.mcdaniel.2009
                    • 1872
                    What are you thinking motor wise Keith?
                      • 9481
                      hey that second one is the 56" fountain that looked so killer
                      actually second and third video!
                      • crrcboatz
                        • Jan 2009
                        • 1103
                        BMC, having posted my thoughts on the 56 size hull from a gas only perspective because that is all i have experience 36yrs in nitro and gas, the difference in the 56 and the 50" apache for speed is night and day.
                        Below is a link to the sale Aeromarine has on the 50" you may want to consider for this project.
                        http://www.aeromarinerc.com/index.ph...mart&Itemid=53
                        Reasons
                        1. I have owned the 50 and the 56 and will tell you the 50 will jump waves VERY well and can hold its own quite well with the larger boat if both have the same power.
                        2. Weight is much different, so is mass in the water.
                        3. The 50 is very stable boat and can take punishment with out worry of rolling over, diving, flipping, etc. Hatch is easy to seal with tape.
                        4. For $175 bucks + shipping you are getting a heck of a lot of boat that is deep, wide, and stable. A proven hull in the gas circles for some time. Much easier to see the 5692 motors in this hull too??? I don't know that but would seem much more likely and for sure less expensive to rig out with the smaller mass in the water.
                        Remember I have had both and the 50 will surprise the heck out of anyone that has not run it.
                        • b.mcdaniel.2009
                          • 1872
                          Another good one...
                            • 9481
                            Reasons
                            Ok, so let me pic your brain a bit
                            I have a Rio51z and like it and will keep it gas, mainly for the runtimes
                            but between the Rio and 50" Aeromarine Apache, what hull will rock the waves better and is more stable in your opinion?
                            thanks
                            • b.mcdaniel.2009
                              • 1872
                              Reasons
                              You really have me thinking here......I can still build a 50" also.
                              • crrcboatz
                                • Jan 2009
                                • 1103
                                Here is a 50" apache doing the same thing wave jumping. See for yourself
