I need a hydro
  • TheShaughnessy
    • 1419
    I need a hydro
    Only fe class that is making the 5 boat min right now is spec and p hydro.
    I want to set up a spec hydro for oval racing.
    Ive been looking at the ul1 but don't really want the hardware or esc that comes with it, also i'm pretty sure i will have to change the AOA on the sponsons to get it to stay on the water (prop side down) in race water.
    Knowing this and that i can't seem to buy a hull only i was wondering what some other options are. I have two t120s and either a proboat 1500 or the actual ul1( though im not sure i want to take it out of my geico) to put in a hull only.
    What else is out there that would do well in spec hydro? Insane hydro? is the miss elam in the same category?
  • LarrysDrifter
    Big Booty Daddy
    • 3278
    I have an h&m viper in the swap shop for sale . Its probably a page or two back.
    • JimClark
      • 5902
      check out the insane hydro it seems rock solid and screams
      Billy Graham
      • TheShaughnessy
        • 1419
        is this the whiplash hull I've been hearing about for p spec?
        if so someone mentioned building it. Did they mean putting the hardware on or actually glueing the boat together?
        what about this one?
        larry, check the other forum
        • sailr
          • 6924
          The Whiplash is a wooden kit that you have to build or have someone build for you. It is a FAST boat. It is what I run. The Insane Hydro sounds great but the price is a bit much for me.
          Mini Cat Racing USA
          www.minicatracingusa.com
          • detox
            • 2310
            The UL-1 is no slouch. It may not be as stable in race conditions as a Whiplash, but it is everybit as fast or faster.
            • properchopper
              rcgoatbuild@snotmail.com
              • 6958
              Mike,
              Look no more; Here's your new boat :
              http://www.offshoreelectrics.com/for...hts=miss+vegas
              I'll knock $35 off the price since you can pick it up. I'll even install your motor, speed control, servo & throw in a set of 4S 5000 maH packs.
              [ If I wasn't "INSANE" I'd never let this boat go - It's Killer !]
              Tony
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 989
                Wow! Merry Christmas.
