Flex Cable assembly... HELP
  • showstoppercat
    • May 2007
    • 95
    Help!! Trying to assembling my own Flex Cable and Prop Shaft
    BUT unable to get my hands on these sleeve retainer type glues in australia (Loctite 603 or Permatex High) the best suggestion from local auto accessorie store is J-B WELD cold-weld compound - any suggestions??
  • martin
    • 2881
    I certainly wouldnt use JB Weld, I have JB weld that i use for many other applications & its very good but not for what you wont to do. Just my personal opinion. You need to check out engineering suppliers or bearing & ballrace merchants/suppliers for Loctite 603. Your probably like we have in the UK, Very difficult to get these retaining Loctites from mainstream shops or even auto shops. They only tend to keep the thread locking Loctites. You can also get it on Ebay but not sure whats on Ebay in Australia. Thanks Martin.
    • martin
      • 2881
      If you cant find any 603 locally go to australia.rs-online.com. They have it. Martin.
      • detox
        • 2357
        Steve sells the 603
        http://www.offshoreelectrics.com/pro...prod=mc-loc603
        • FRED
          • Jul 2007
          • 232
          Just clean both parts and use silver solder with a small torch on low heat, just enough to let solder melt and push cable into shaft.Clean shaft afterwards.
          • siberianhusky
            • Dec 2009
            • 2206
            I second the silver solder, need it anyway to solder up the cut end to keep it from unwinding. Personally I have never used the glue method. Been soldering them since the mid 80's.
            Good borax flux and a quality silver bearing solder, never had any problems soldering them or having them fail.
            Plus I can have a brand new cable ready to go in the boat in about 5 minutes. No cure time for solder, once it's cooled it's ready to go!
            I also silver solder clevises and such to control rods, super handy stuff to have around and just as easy as soldering electronics, just use a micro torch and watch the heat.
            Probably cheaper than the bottle of Loctite and no shelf life!
            Do not use regular acid flux or electronic rosin flux! Borax flux!
            Clean the stub and cable really well, brush a bit of flux on the cable, drop a small piece of solder in the stub shaft, slide in the cable and heat until the solder flows up the cable and it bottoms out in the stub.
            Don't use too much solder or it can wick farther up the cable than you want it to.
            I believe the Sta-Brite kit is about 10$ for flux and 3' of solder. Last time I bought one was about 5 years ago and still wave about 2' of solder left.
            • Basstronics
              • 2384
              You can buy almost anything on the internet!
              http://cgi.ebay.com.au/LOCTITE-648-5...item33665ad620
              • 785boats
                Wet Track Racing
                • 3423
                Showstoppercat.
                Any local bearing supply outlet will have the Locktite range
                the last time I tried to get the 603 they told me that here in Australia it has been replaced by the 609 so that's what I bought.
                But the silver solder is the better way to go.
                Cheers.
                Paul.
                • martin
                  • 2881
                  609 is different stuff ita a medium strength retainer of 2290 psi, 603 is high strength retainer of 3260 psi. Thanks Martin.
                  • showstoppercat
                    • May 2007
                    • 95
                    Thanx boys will go hunting today -
                    Question why not JB Weld???? looks like a great and easy product to use
                    • siberianhusky
                      • Dec 2009
                      • 2206
                      Strength
                      • showstoppercat
                        • May 2007
                        • 95
                        I only ask cause the boys in my local auto accessories store have joined two piston rods together (with JB Weld) and the join looks very strong
                        • FRED
                          • Jul 2007
                          • 232
                          showstoppercat; if you ever have to remove a jb weld cable shaft from cable, you'll answer your own ? Jb weld is put into place, it's PERMANENT.
                          • showstoppercat
                            • May 2007
                            • 95
                            Thanx boys - just found some permatex sleeve retainer woohoo
                            • martin
                              • 2881
                              Retainers like loctite are designed to work with very close fitting parts whilst having a very strong bond. Stuff like JB Weld being a thick paste dosnt work that well when you have close tolerences like a flex shaft as theirs not as strong a bond with such a thin amount of glue in their. Martin.
