what the ??????
  • Doug Smock
    • 5264
    #46
    It looks to me like they are trying to find a remedy for the stator wires fatiguing from being moved around. What their techs call "unsupported".
    This happened to me on a 1527 that was in and out of a boat, and I witnessed the same thing on a older 1515 1Y. What happens is you loose a strand or two at a time between the soldered portion of the "wire" and the stator eventually leading to motor failure.
    But hey, go ahead and set up the gallows. Leave the rope a little long, some say the culprits may be short in stature.
    D.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Rumdog
      • 6453
      #47
      Rail mounts wiil work fine. There is no reason you have to put the mount where the screw heads stick out.
      • Boatman
        • 796
        #48
        Wha?? If the motor can is covered by a cooling can there is no where else to put the straps
        • Rumdog
          • 6453
          #49
          Remedy: 1527, 1521 cooler. 1521, 1515 cooler. 1515, 1512 cooler.
          Also, if you have a dremel it's pretty simple to notch the mount enough for the side of some screw heads.
          • m4a1usr
            Fast Electric Addict
            • 2032
            #50
            This happened to me on a 5127 that was in and out of a boat, and I witnessed the same thing on a older 1515 1Y. What happens is you loose a strand or two at a time between the soldered portion of the "wire" and the stator eventually leading to motor failure.
            D.
            I luv ya Doug! Its always little tid bits that add to the bigger picture. I agree with you 100% on the logic. All my Neu's are built with the older motor leads comprised of stator wire extensions. Thats one of the things years ago that had me questioning the CC/Neu series. I could not see why anyone would end the stator windings only to add extension wires out of the can. Now it makes sense. An answer to wire flex wear. Now I understand why my last Neu 1512 has those darn grommets in the end bell supporting the wires.
            John
            Change is the one Constant
            • Meniscus
              Refuse the box exists!
              • Jul 2008
              • 3222
              #51
              Tony, cooked a Castle and it wasn't on the edge. I haven't opened up yet, but I'm willing to guess they are non-segmented and it threw a magnet. May be an exception, but that's my experience. In my case, it may very well be that they can't handle the RPM.
              • Alexgar
                • Aug 2009
                • 3522
                #52
                They have a wrap around the rotor must have been a fluke
                • don ferrette
                  • 1093
                  #53
                  D.
                  I still like the motors, just think that there's got to be a better way around this. Not to mention I'd like to see at least 10AWG rather than 12 but hey that's just me. Maybe all this will result in some "tweaks" to make it better......
                  - IMPBA Hall of Fame -
                  - IMPBA Hydro Technical Director -
                  • HOTWATER
                    • 2323
                    #54
                    I ordered a Neu 1515 1Y motor from Steven early this year and the motor wires are all black...no extra shrink on the wires after the endbell and no exposed wires inside the endbell that I can see, The covering on the wires seem a bit different than the covering on my Hyperion lipo leads....is this a good thing? Hopefully I won't have any problems with this one...anybody?
                    "Will race for cookies!"
                    IMPBA D12
                    • Doug Smock
                      • 5264
                      #55
                      That sounds normal to me Kent.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • HOTWATER
                        • 2323
                        #56
                        Good to know...thanks SIR!
                        IMPBA D12
                        • carlcisneros
                          • Jan 2010
                          • 1218
                          #57
                          any word yet from Neu?
                          • RandyatBBY
                            • 3915
                            #58
                            D.
                            I was thinking the same thing. If you have a flexible wire coming out of the can it can go any direction and keep it shorter. The old way I have always been scared about breaking the motor wires from multipliable bends time after time. As long as the wires do not come out of the can it is ok and when it does they warranty for life of the windings.
                            Randy
                            BBY Racing
                            • properchopper
                              rcgoatbuild@snotmail.com
                              • 6958
                              #59
                              I got an e-mail from Steve Neu recently in response to my inquiry about needing to make a 90 degree bend on the wires of a new 1521 1.5D which I got from Neu last February. The wires were as stiff as (insert your own analogy here), but Steve said go ahead and bend them after they exit the endbell at least 1/4". I think I'll go back and fab a "support" for them anyway.
                              • T.S.Davis
                                • 6228
                                #60
                                I'm pretty sure that bending the wires around is how one of the 2215's I have was baked. Bend bend bend grounded to the can maybe.
                                Noisy person
