IMPBA’s new P-limited “spec” class rule proposal.
  • raptor347
    • Jul 2007
    • 1177
    #151
    The funny part of all this is I've only had one motor failure in competition, and it wasn't a burnt winding (rotor failure). I've failed a few in testing, but I also know the limits of my equipment. I don't guess and hope it holds together.
    My spec boats run 85 amps average with corner spikes as high as 130. Those numbers apply to hydro, tunnel and sport hydro. I have lots of data logs for all these setups. It's the safe limit of the motor. Once you get there, it's time to work on efficiency and driving.
    If the class requires you to run a stock esc, put an oversized esc and a data logger in the boat for testing. Then tune it to the survivable current level of the required equipment. No failures, no smoke, but you do need a little extra equipment and testing time. When you know the limits of the equipment, you can get very close to that edge and still have great reliability.
    Those who are willing to sacrifice equipment seldom win because failures always crop up at the most inconvenient times. You have to finish to win.
    The real problem is what works on one hull doesn't always work on another, finding the limit for a given boat can be a challenge. For example, Eric Bourlet and I did a bunch of testing last season to find the limits of what the motors would take. The prop that ran perfect on my Raptor would kill the motor in his JAE. The best prop on his boat didn't perform on mine.
    Then there's the maintenance thing. Everything has to be maintained or at some point something will bind/fail and overload the system. Running a stock or aftermarket esc won't make a difference in this case. The most common failures are due to poor setup and poor maintenance.
    Stock/spec classes have always been the most tuning/setup critical. People often make the mistake of equating stock/spec with novice/entry level. In many cases a stock/spec class is the most challenging.
    You guys all know I'm an FE nut, but I've learned an awful lot from my friends running nitro and gas. To the point that I'm also running gas now. One of our great failings in FE is not doing enough testing. With the open power systems, traditionally we (note I include myself here) just throw more prop at it until we got to the performance we wanted or the smoke gets out. With the power limitations of P-spec, it's not a case of more prop, it's coming up with a better prop. Same goes for boat design. It really won't matter if the esc's are spec'd or not, the best driver with the most refined boat will have a distinct advantage. With the availability of relatively inexpensive data loggers, there really isn't much of an excuse for smoked equipment.
    It truly doesn't matter to me one way or the other on the esc. I can make a boat work either way. We've run the class both ways up here since we started playing with it in 2007. The best you can do is come up with a set of enforceable rules that works for the organization. If it works and draws more participation, it's all good.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    • Doug Smock
      • 5359
      #152
      Why test with a higher rated ESC? Because the motor is the fuse?? LOL Just playing with ya Brian.
      There is another way. You know, the one we use on all the rest of the fleet. It has certainly worked for us
      I'll see ya at the pond!!!!
      Smock out!!!
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • egneg
        • 4759
        #153
        Don, we all knew Egneg was goofing about the DNF's with nitro. It's an electric forum with electric nut jobs talking about potential electric rules. Offending the fossil guys wasn't exactly a concern in the thread.
        Thank you! I have the utmost respect for the members of ODMBA as they afforded me the opportunity to race my FE boats. I think we have all learned quit a bit this past year on both sides. This is evident as many of the gas/nitro guys are now building FE boats. Just set it in the water and go!
        IMPBA 20481S D-12
        • egneg
          • 4759
          #154
          Originally posted by Meniscus View Post
          On another note, not picking sides or defending comments made by any parties, but for the record: I've only heard positive things from Chuck regarding IC folks at Old Dominion in every instance. After all, they share the same hobby.
          Ben - I thank you for this statement. The IC guys now know the advantages of running FE boats and things will get better in the future. As I have stated before they have a rather large investment in the equipment they are using so things will be a bit slow in changing - but they will change. With the green crowd pressing for new laws the IC guys are finding it hard to find places to run.
          IMPBA 20481S D-12
          • T.S.Davis
            • 6266
            #155
            Originally posted by D.Smock View Post
            Some just have to push and push these limited setups ( you don't have to look far to see it) and that is what sparked the concern, and why some folks want restrictions on them.
            but but but........how are you defining "pushing the limit"?
            Walk with me...... haha
            I run a bone stock UL setup in my Spec Sport. However, I built a sport that looks like something from outer space. It's fast enough and drives like a Caddy. Am I pushing the limit? Will that make my boat win? Yep. Sometimes.
            If Brian shaves a prop down, cups the poo out of it, and finds the absolute perfect combo for his boat and motor (we know he can). Isn't that too pushing the limits. Does he win that way? Frequently.
            Is it fair? It's racing. Of course it's fair. It's a limited spec. Not spec. If you want true "spec" you almost need to do hand outs on the batteries, motors, prop and esc.
            All that design and prop tweaking still wont beat a better driver in my experience.
            Noisy person
            • Doug Smock
              • 5359
              #156
              I'll walk with ya Terry but I'm not holding your hand.LOL
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • T.S.Davis
                • 6266
                #157
                Doug
                Wise. They're sticky with epoxy. Explains the brain damage though.
                Noisy person
                  YYeah, yeah, epoxy my foot!
                  • Doug Smock
                    • 5359
                    #159
                    Oh man me too, that would have been ugly.
                    I just finished sealing up a P -Limited hydro, lol
                    Hang tough and have fun fellas!!
                    D.
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • T.S.Davis
                      • 6266
                      #160
                      Epoxy on your foot? There's a better way Ray. Wait....how'd you get it on your foot? Never mind, don't want to know.
                      Noisy person
                      • bbill1
                        Tunnelboat Mafia Member
                        • Feb 2011
                        • 127
                        #161
                        I have been sitting back in my lazy boy with a bag of popcorn watching this go on and on.
                        Seems to me that a few have forgotten what this is supposed to be all about.
                        I am a nitro tunnel vet who has decided to jump into FE. Of course my first thought is to get started in the P-spec class since I am a newcomer and want to see if I like it before I really dig in.
                        My two cents is this:
                        P-Spec should be for those who are new to the FE side of things and want to race without spending a mint. You want to start going faster or get better ecs's and motors? Create the P mod class. This is equivalent to our B MOD Tunnel class (Namba).
                        Our B Sport Tunnel class basically has one motor offering, the OS MAX @ $375.00. Talk about propping up a manufacturer, this is it. But we don't have the bickering that you guys have and I think it is because we all realize that the B Sport class is primarily for the beginner tunnel head. Sure the veterans still run the class but we all understand why it is there. Wanna go faster? build a mod boat.
                        So this is how I see it.
                        P-Spec should be just that. Aquacraft and Proboat ecs's and motors. Nothing else. I personally don't care if I am supporting only one or two manufacturers. I just wanna race...
                        Want to go faster, or get bigger esc's and motors? No problem, go for it! But you will run it in the P (mod/open) class instead.
                        Got my flame suit on.
                        Bill Britton
                        Current IMPBA P-O/B Tunnel SAW record holder with avg time of 3.358 seconds @ 67.004 MPH.
                        Owner Worlds fastest record setting Lynx with average time of 3.287 seconds @ 68.451 MPH.
                        Smocktura Props!
                        • Darin Jordan
                          • 9446
                          #162
                          WHY is it that only "new" people get to save money??? So, once you've raced a few years, you are REQUIRED to go out and spend a mint??
                          Darin E. Jordan - Renton, WA
                          • bbill1
                            • Feb 2011
                            • 127
                            #163
                            No... Only if you want to go faster.
                            Seems to me the problem is with the implementation of the rules.
                            They were not PROPERLY in place BEFORE people started popping for 120amp ecs's. now that there is a push to standardize the rules, Only those who would need to now go out and buy a legal esc under the new rules are the one's balking. ( And I wouldn't actually call 160.00 for a 60 amp esc and a motor for the P-Spec class a "mint".)
                            Your making it harder than it needs to be.
                            Smocktura Props!
                            • Diegoboy
                              • Mar 2007
                              • 7443
                              #164
                              What you're describing bill is the RTR class. This isn't about speed or going faster.
                              • DPeterson
                                • 991
                                #165
                                Here you go;
                                THE ELECTRONIC SPEED CONTROL DEVICES FOR THE P-LIMITED CLASSES SHALL BE OF ANY BRAND, STYLE AND SIZE UNLESS OTHERWISE INDICATED OR RESTRICTED BY INDIVIDUAL CLUBS, DISTRICTS OR VENUES.
                                I will never support inconsistencies in rules across the country or from one association to another but it seems this issue is going to take some time to smooth out. This paragraph can get everyone started.
                                Good luck. I am out for now. Racing in Arizona. We got rules that we can travel with.
                                Doug
                                Doug Peterson
                                IMPBA 19993
                                www.badgerboaters.com
