Originally posted by crystalclearvisual
View Post
Leopard 4 pole 3674 1700KV brushless motor 2 turn Y wind
Specification:
Max voltage: 34V
Max Amp: 78A
Max power: 2400W
RPM: 1700KV/volt
Resistance: 0.009
Non-load current(7.4V): 2.3A
Diameter: 36mm
Length(excluded shaft): 60mm
Weight: 315 gm
Mount hole depth: 7mm
Shaft diameter: 5mm
Shaft lenght: 18mm
Leopard 4 pole 3674 1900KV brushless motor 2 turn Y wind
Specification:
Max voltage: 34V
Max Amp: 78A
Max power: 2400W
RPM: 1700KV/volt
Resistance: 0.009
Diameter: 36mm
Weight: 315 gm
Shaft diameter: 5mm
Shaft lenght: 18mm
Do you think running 1900kv on 22.2v is to much?
