Best setup for single drive Apparition
  • crystalclearvisual
    Andrew Shepherd
    • 31
    #31
    Originally posted by crystalclearvisual View Post
    thanks matey
    Hi Mate, ok i have decided to go for 1 of these 2 babys
    Leopard 4 pole 3674 1700KV brushless motor 2 turn Y wind
    Specification:
    Max voltage: 34V
    Max Amp: 78A
    Max power: 2400W
    RPM: 1700KV/volt
    Resistance: 0.009
    Non-load current(7.4V): 2.3A
    Diameter: 36mm
    Length(excluded shaft): 60mm
    Weight: 315 gm
    Mount hole depth: 7mm
    Shaft diameter: 5mm
    Shaft lenght: 18mm
    Leopard 4 pole 3674 1900KV brushless motor 2 turn Y wind
    Specification:
    Max voltage: 34V
    Max Amp: 78A
    Max power: 2400W
    RPM: 1700KV/volt
    Resistance: 0.009
    Diameter: 36mm
    Weight: 315 gm
    Shaft diameter: 5mm
    Shaft lenght: 18mm
    Do you think running 1900kv on 22.2v is to much?
    Andy Shepherd
      Andrew Shepherd
      • 31
      #32
      Specification:
      Max voltage: 34V
      Max Amp: 78A
      Max power: 2400W
      RPM: 1700KV/volt
      Resistance: 0.009
      Diameter: 36mm
      Weight: 315 gm
      Shaft diameter: 5mm
      Shaft lenght: 18mm
      Specification:
      Max voltage: 34V
      Max Amp: 78A
      Max power: 2400W
      RPM: 1700KV/volt
      Resistance: 0.009
      Diameter: 36mm
      Weight: 315 gm
      Shaft diameter: 5mm
      Shaft lenght: 18mm
      Andy Shepherd
        Andrew Shepherd
        • 31
        #33
        Originally posted by tiqueman View Post
        My exact thoughts as well. That motor will not handle 6S. I wouldnt go more than 4 on it.
        I Cooked my Stock motor in less the 5min on 6s
        Andy Shepherd
