Looking for Power Analyzer that is simple to use to keep track of the current draw so I can prop my set up correctly thanks Chris
Power Analyzer Quest.
If your ESC doesnt have a data logger function, newer ones are showing up with this capability more and more, then get yourself a Eagle Tree or Medusa. Both good units. There are others too but I know those 2 and they work great. Keeping a written log helps as your build performance increases to. For years I winged it using just my memory. Problem was I started repeating the same mistakes over and over. Now I have a nice library to reflect upon and ensure I wont waste time or energy.
JohnChange is the one Constant
eagle tree
Go to eagletreesystems.com. Depending on your amp draw, there are 2 data loggers you can use. One is wired in series and one uses an inductive pickup for higher amp draws.Fast Electrics Have A Small Carbon Wake
this is what I have Home » Electronic Speed Controls » Brushless Speed Controls
Click picture for details! Product ID: ker-seaking-180
Hobby Wing SeaKing 180
In Stock: 13 Details
Hobby Wing "SeaKing" 180 Amp ESC.
This is boat model, specially designed for boat use with water-cooling system and the esc is water resistant.
Special designed for RC boat, with excellent start-up, acceleration and linearity features.
With 2 running modes ("Forward" mode and "Forward/Backward" mode). Multiple protection features: Low voltage cut-off protection for lithium or nickel battery / Over-heat protection / Throttle signal loss protection. With 8 steps of timing adjustment, compatible with all kinds of sensorless brushless motors.Swtching mode built-in BEC has a very powerful output even working with 6 cells lipo battery.User programmable and compatible with the pocket-sized Digital LED Program Card (Optional equipment) to set the ESC easily.
Price: $104.99
If your buying it from OSE/ Steve then pay that. He deserves our money. Dont pay that from any Chi seller. Thats way too much. You need a source PM me. As far as a data system the T180 (thats the one you have listed) does not have a data logger function. You will need to get one. Pretty much just plan on getting one. You decide which you like the best. I like my Eagle Tree best. But Medusa has a 200amp version too plus it gets great revues from other RC sources.Originally posted by dasboata View PostPrice: $104.99
I did buy it From SteveOriginally posted by m4a1usr View PostIf your buying it from OSE/ Steve then pay that. He deserves our money. Dont pay that from any Chi seller. Thats way too much. You need a source PM me. As far as a data system the T180 (thats the one you have listed) does not have a data logger function. You will need to get one. Pretty much just plan on getting one. You decide which you like the best. I like my Eagle Tree best. But Medusa has a 200amp version too plus it gets great revues from other RC sources.
John
