Power Analyzer Quest.
  • dasboata
    • Dec 2010
    • 3972
    Looking for Power Analyzer that is simple to use to keep track of the current draw so I can prop my set up correctly thanks Chris
  • m4a1usr
    Fast Electric Addict
    • 2036
    If your ESC doesnt have a data logger function, newer ones are showing up with this capability more and more, then get yourself a Eagle Tree or Medusa. Both good units. There are others too but I know those 2 and they work great. Keeping a written log helps as your build performance increases to. For years I winged it using just my memory. Problem was I started repeating the same mistakes over and over. Now I have a nice library to reflect upon and ensure I wont waste time or energy.
    John
    Change is the one Constant
    • morewattsnow
      • Oct 2010
      • 236
      eagle tree
      Go to eagletreesystems.com. Depending on your amp draw, there are 2 data loggers you can use. One is wired in series and one uses an inductive pickup for higher amp draws.
      Fast Electrics Have A Small Carbon Wake
      • dasboata
        • Dec 2010
        • 3972
        this is what I have Home » Electronic Speed Controls » Brushless Speed Controls
        Click picture for details! Product ID: ker-seaking-180
        Hobby Wing SeaKing 180
        In Stock: 13 Details
        Hobby Wing "SeaKing" 180 Amp ESC.
        This is boat model, specially designed for boat use with water-cooling system and the esc is water resistant.
        Special designed for RC boat, with excellent start-up, acceleration and linearity features.
        With 2 running modes ("Forward" mode and "Forward/Backward" mode). Multiple protection features: Low voltage cut-off protection for lithium or nickel battery / Over-heat protection / Throttle signal loss protection. With 8 steps of timing adjustment, compatible with all kinds of sensorless brushless motors.Swtching mode built-in BEC has a very powerful output even working with 6 cells lipo battery.User programmable and compatible with the pocket-sized Digital LED Program Card (Optional equipment) to set the ESC easily.
        Price: $104.99
        • m4a1usr
          • 2036
          Price: $104.99
          If your buying it from OSE/ Steve then pay that. He deserves our money. Dont pay that from any Chi seller. Thats way too much. You need a source PM me. As far as a data system the T180 (thats the one you have listed) does not have a data logger function. You will need to get one. Pretty much just plan on getting one. You decide which you like the best. I like my Eagle Tree best. But Medusa has a 200amp version too plus it gets great revues from other RC sources.
          John
          • dasboata
            • Dec 2010
            • 3972
            John
            I did buy it From Steve
