I havn't done it but you can try citristrip it's a natural paint striped that is not as abrasive as a lot of others as long as you keep an eye on it I'm sure it will do the job. http://www.wmbarr.com/citristrip/default.aspx
Try brake fluid, If I remember correctly it's used it to strip plastic Model RR projects when they want to repaint to a diffrent roadname.
As allways "TEST" first.
Hope this helps ?
T.C.
Try a spray called Purple Power. It's a cleaner and degreaser. I used it on a couple of plastic models. Worked well. Got it at Walmart. If you let it sit til it dries the paint flakes right off.
Billy Graham
Yup. That's it. Worked well for me. You can even get gallons and dip plastic into it to remove paint. I've never had a problem. But as usual try it on a small spot first on whatever you are going to use it on first to make sure. Good luck.
Billy Graham
Test it before you fully commit, but Citri-Srip is what I use as well and it seems to do just fine...
Darin E. Jordan - Renton, WA "Self-proclaimed skill-less leader in the hobby."
Hope this helps ?
T.C.
It works well for small parts that can be submerged but I don't think it's practical for a boat hull.
