stripping paint off a Vac-U-Pickle
  • JimClark
    • 5913
    anyone ever stripped paint (krylon Fusion) off of a Vac-U-Pickle?
    looking for ways of stripping it without damaging the hull
    Billy Graham
  • monojeff
    • Nov 2010
    • 2728
    I havn't done it but you can try citristrip it's a natural paint striped that is not as abrasive as a lot of others as long as you keep an eye on it I'm sure it will do the job.
    http://www.wmbarr.com/citristrip/default.aspx
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • T.C.
      • Sep 2009
      • 245
      Try brake fluid, If I remember correctly it's used it to strip plastic Model RR projects when they want to repaint to a diffrent roadname.
      As allways "TEST" first.
      Hope this helps ?
      T.C.
      • rcjrboatman
        • Jul 2009
        • 47
        Try a spray called Purple Power. It's a cleaner and degreaser. I used it on a couple of plastic models. Worked well. Got it at Walmart. If you let it sit til it dries the paint flakes right off.
        • JimClark
          • 5913
          this one?
          Billy Graham
          • rcjrboatman
            • Jul 2009
            • 47
            Yup. That's it. Worked well for me. You can even get gallons and dip plastic into it to remove paint. I've never had a problem. But as usual try it on a small spot first on whatever you are going to use it on first to make sure. Good luck.
            • JimClark
              • 5913
              Thanks I have an extra cowl so I will try it on that.
              Thanks much
              Jim
              Billy Graham
              • Shooter
                Team Mojo
                • Jun 2009
                • 2752
                Let us know how this goes Jim. Styrene is pretty low on the list for chemical resistivity.
                • JimClark
                  • 5913
                  Will do I need to track down some of that degreaser mentioned above
                  Billy Graham
                  • Darin Jordan
                    • 9446
                    Test it before you fully commit, but Citri-Srip is what I use as well and it seems to do just fine...
                    Darin E. Jordan - Renton, WA
                    • sailr
                      • Nov 2007
                      • 7128
                      Interesting to know. I didn't think anything would be benign enough on ABS or styrene! Thanks!
                      Mini Cat Racing USA
                      www.minicatracingusa.com
                      • JimClark
                        • 5913
                        Purple power purchases and i have sprayed some on the cowl to test
                        Billy Graham
                        • sailr
                          • Nov 2007
                          • 7128
                          Be careful with that stuff. It will eat the skin on your fingers. You'll be 'molting' for days!
                          Mini Cat Racing USA
                          • egneg
                            • 4759
                            Hope this helps ?
                            T.C.
                            It works well for small parts that can be submerged but I don't think it's practical for a boat hull.
                            IMPBA 20481S D-12
                            • JimClark
                              • 5913
                              The Degreaser will?
                              Billy Graham
