Twin HOTR Options, need help from you smart people!
  • forescott
    Hopelessly Addicted to RC
    • 2686
    #46
    I have the typhoon. Its pretty powerful for its size, but if going the outrunner route I would use the castle 1800kv's. They are slightly larger and only 40-bucks a piece with the castle sale.(plus I wanna see how well they work)
    • Diesel6401
      Memento Vivere
      • 4203
      #47
      Originally posted by blackcat26 View Post
      Diesel, I think that the Typoons will be pretty under powered for that size hull.
      Ok thanks, what about the outrunners Forescott listed?
      Those look badass, maybe a winner, let's see with the twin experts think. Good price that's for sure.
      - Diesel's Youtube
      - Diesel's Fleet
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        #48
        I think chuck e cheese used the typhoon in his hotr cat and was running 50-60 if I recall correctly.
        I'm no prop guru but I beleive de-toungued props has lees holeshot and more top end. But with twins you have twice the blade area so it doesn't make much matter. Adding cup and or pitch will redirect the thrust cone so you'll have more speed. Counter rotating props are limited in sizes so alot will be modified.
        • blackcat26
          High Speed Junkie
          • Sep 2009
          • 1598
          #49
          Baked, was that single drive or twin?
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            #50
            I stand corrected it was 50-55 and motor was a t-600 not too sure if that's the same. Yes it was a single.
            http://forums.offshoreelectrics.com/...light=Copy+cat
            • blackcat26
              High Speed Junkie
              • Sep 2009
              • 1598
              #51
              T-600 is a whole nuther animule! That is a 3000w motor. At least double if not triple the power of the Typhoon.
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1679
                #52
                My bad. I'm not familiar with the HK outrunners. My little brain was thinking "T" = typhoon. Now back to your usuall programming.......lol
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3278
                  #53
                  The T-600 sounds sweet.Anyone have a link?Are they good for a twin set up?
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1598
                    #54
                    http://www.hobbyking.com/hobbyking/s...dProduct=11980
                    Big heavy and powerful. Gonna need some room for the batteries this baby will use. I have one I bought in the swap shop and was gonna run in the Geico but dont have a 6mm to .150 coupler.
                    • ron1950
                      • 3024
                      #55
                      without trying to steel the thread d,,,,how do u rate motors to see what rpm they will run etc? i am doing the same thing with a twin and dont have a clue what motors to use///
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        #56
                        Kv x voltage=rpm.Twins can usually run mid 30k rpm or up to 40k with a high quality motor with good bearings.
                        • ron1950
                          • 3024
                          #57
                          ok thanks larrysdrifter 30k sounds like a good thing...wonder if two ul=1 motors would be worth a darn in a hotr on 2 4cells
                          • tunnelvision
                            • May 2010
                            • 685
                            #58
                            Looking good Diesel! Not sure how fast you want to go but I just installed the Leopard 2860 2730kv in my 25" Prince mono and it runs awesome. Setup is 3s 5000mah 30c Turnigy, 3/16drive /.150 flex spinning a x637 (for now) and hit 40mph with low temps. My batts were 94, esc 70 and motor was 80 after a 5 minute run. I like this Apparition hull and am wanting to get one. Can't wait to see the finished product.
                            Go Fast...Turn Right...
                            • LarrysDrifter
                              Big Booty Daddy
                              • May 2010
                              • 3278
                              #59
                              Got my 32" cat from Ben today!!!!Gonna start a build thread this evening.
                              • Diesel6401
                                Memento Vivere
                                • 4203
                                #60
                                Just so all of us are on the same page this is the motor I have http://www.hobbyking.com/hobbyking/s...idProduct=9258. I planned on using in a BJ26, but I also have suppo outrunner coming that I can use instead. Since i have one and they are priced cheap they may be worth a try. Once I open the motor mount to except 25mm bolt patterns the sky is the limit. It maybe worth a $50 try for fun. I love that outrunner sound!
                                Blackcat, Larry and Tiq. Did you guys looks at the CC outrunners Forescott posted yet. Opinions on those?!?
                                - Diesel's Youtube
                                - Diesel's Fleet
