Originally posted by tiqueman
View Post
lol1
SUPPO™ Speed Controller Programming Instructions
For Advance programmable Normal Boat ESC
70A/125A/200A ESC
Important Note: Some of these ESCs are Opto, without BEC to your Receiver,
you need extra power source for your receiver. You can use a UBEC, a voltage regulator,
or extra batteries as the power source for your receiver. If you hear the music tone repeat
again and again for more than 3 times, you may need to check your power source to the
receiver.
·Phrases 1 Enter programming Mode
1. Connect your motor and receiver to the speed controller, but do not connect the
battery yet.
2. Turn on your transmitter and move the throttle stick to the full throttle position (full
up). Please Note: Most Futaba transmitters have the throttle channel reversed by
default.
3. Connect your battery and the controller will initialize with a musical tone.
·Phrases 2 Programming
After 3 seconds, the motor will start beeping a sequence of tones – a musical tone followed
by one or more beeps. Each sequence represents a parameter that you can program and is
repeated 3 times. The parameters are:
Music Tone + 1
Beep
Options 1. Cell Type and No. of Cells
Music Tone + 2
Beeps
Options 2. Throttle Setting
Music Tone + 3
Beeps
Options 3. Brake Setting
Music Tone + 4
Beeps
Options 4. Direction and Cutoff Type
Music Tone + 5
Beeps
Options 5. Timing Mode
Music Tone + 6
Beeps
Option 6. PWM setting
Step 1. Starting, Enter Sub-optins. When you hear the sequence for the parameter you wish to
program, move the throttle stick to the Center Position to Enter Sub-options.
The controller will then start beeping a Morse code sequence of short and long beeps
representing the possible options you may choose for the selected parameter. See table 2 for
a list of all programmable options. Each option sequence is repeated 3 times.
Step 2. Select and save, the select the option, move the throttle stick back to the
