Would this work ???
  • Brushless01
    • Apr 2010
    • 489
    Would this work ???
    Hi there just built a delta force 29 knock off with speedmaster hardware sv power and spektrum radio gear runs consistantly 35mph on 4s. Anyway what I was wondering is since the castle creations motors are so damn cheap would a 1518 work in this hull, with a turnigy 180 amp esc ?? I would run 4s lipo. The boat will be used as a sport and race boat not in a race class just messing about with all sorts of other fe boats.
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Brushless01
    • Apr 2010
    • 489
    Anyone ??
    • ENCORE MAN
      • Jan 2010
      • 1096
      Originally posted by Brushless01 View Post
      Anyone ??
      Hi, I just bought a Castle Neu 1512/1800 KV for my DF29. I have been running a Nemesis 8 xl and m445 prop.The boat runs around 50 mph on this set up. The new motor only draws 80 amps on 4s so my Etti 150 should work well. I think the 1512 is more than adequate but if not, it will make my 25 Prince just howl. BG
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        I've run the 2650kv 1512 to 58 mph on 4s w/T180 x440 in a 32" cat. It's a strong motor, the 1515's and the 1518's are even stronger. I would say with confidence that it's no sweat for the 1518 motor to pull the 29" hull. I would say you could run the 1518 1800kv on 5s/6s even.
        It's a Nice Setup. Rock On.
        • Rumdog
          • 6667
          The 1518 on 5s will get you to 60 mph with the right prop in that hull.
          • Brushless01
            • Apr 2010
            • 489
            What prop would be best prop then for the 1518 ??. Also im getting a pursuit mono aswell and im wondering what would be best a 1717 or a 1520 ?
            Thanks
            • Brushless01
              • Apr 2010
              • 489
