BTW b.mcdaniel, here is a buddies Gen with the Neu combo on 6s just for a look, he's pushin 60..............
Genesis/ help/advise with a fast setup!!
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
FYI the Neu 15 series and the Leopard 40xx series are 40mm and can be installed in the stock motor mount with the addition of a 40mm tail ring.
I stuffed a 1527 in mine. I can hit 60+ but it tends to spiral flip itself out of the water. If I built another I would use a smaller motor and more rpm to reduce the prop size in hopes of increasing hull stability. Like a 1700kv on 6s w/m445... but that's theory and probably would last long at that RPM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Fighter, is there enough room for a jacket as well for a 15 series with the stock mount?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I use a vac-u-pickle mount with a 4074 in a skunk cat and it's a winner.Attached Files
I remember that vid you posted before wake awesome. My motor had more in the tank, I just didn't have time or the want to dial in the hull. If I could have got the CG figured out and the hull dialed in I could have got higher then low 50s with mine. I only ran the boat twice tough and sold it lol...
What I did was use the stock mount and bought a second mount and used the stringers and tail ring. Using the stringers to move the tail ring back.Originally posted by Make-a-Wake View PostFighter, is there enough room for a jacket as well for a 15 series with the stock mount?
If you're bored, the thread is quite entertaining, it bounces all over the place.
http://forums.offshoreelectrics.com/...t=14531&page=5FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Ya ive seen your custom setup and thought it was sickOriginally posted by Make-a-Wake View PostBTW b.mcdaniel, here is a buddies Gen with the Neu combo on 6s just for a look, he's pushin 60..............
http://www.youtube.com/watch?v=111tP0GD7us
..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
That would be the max i would ever go with an XL...........i think 13 or 14XL would be better..........cooler running and a bit bigger prop.Originally posted by xxxrems38xxx View Postand with a 12xl on 6s how it would work?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Got another vid of my Buddies Genesis............man, this thing is stupid fast. He rolled it in the first turn, but stayed upright, then went to tearing up the track. 54.5 mph verified GPS, and he's still got room.
I'm still not sold on a xl motor in this boat. I think it's just too big... I gps'd 53mph on mine with a 580 on a m445.
For decent speeds and a dollar conscious, quality, "bulletproof" setup, i still think the Leopard 4074 is enough. Although the big Neu in my buddies sure looks fun!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
1400kv or 1774kv, I think he may go with a 4082 leopard which wouldOriginally posted by Make-a-Wake View PostFor decent speeds and a dollar conscious, quality, "bulletproof" setup, i still think the Leopard 4074 is enough. Although the big Neu in my buddies sure looks fun!
Nice!Originally posted by Diesel6401 View Post1400kv or 1774kv, I think he may go with a 4082 leopard which would
Made up my mind.Going with the 4082 leopard with the 180amp.esc i have!!!!!!!!! Whatcha think about that??..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
