Genesis/ help/advise with a fast setup!!
  • b.mcdaniel.2009
    • 1872
    If i wanna hull A#$ in my Genesis cat. what set up does anyone recommend?Nothing that cost over $350 total in motor and esc. ill either run on 4s or 6s lipo's!!I just wanna tear some ponds up!!! LOL!!
    Then what prop should be ran!
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
  • Alfa Spirit
    • 2183
    - 6S
    - 540XL motor 1500kV
    - Seaking 180A
    - X442 or X642 or X445 propeller
    • Make-a-Wake
      FE Rules!
      • 6057
      "Nothing that cost over $350"
      This motor and ESC = $349.99 LOL, run the 1y on 6s...............55mph+
      http://www.offshoreelectrics.com/pro...u-1521&cat=117
      http://www.offshoreelectrics.com/pro...er-seaking-180
      • Diesel6401
        Memento Vivere
        • 4391
        I used a 580 7L in mine (vid in my signature), I would go with Make's post. Good set-up, I think the xl's are too small for the 37" genesis. A Leopard would rock as well either the 1400 or 1774. I like the neu setup though myself
        - Diesel's Youtube
        - Diesel's Fleet
        • b.mcdaniel.2009
          • 1872
          damn man your Genesis fly's!!!!!
          • b.mcdaniel.2009
            • 1872
            Big difference in prices of those two motors. $245.00 and the others 89.00.Wat up with that.
            I just got the Genesis in the mail today!!! This thing looks tuff!
            • Diesel6401
              Memento Vivere
              • 4391
              It ran 100% better with the batteries as far forward as they could go and a CF45 prop. In the video I was playing with the CG and it had a m445 on it, but it ran better on the other set-up I just didn't have video for it. 48mph with that motor on a CF45 and 50+ with the m445. I think the video it ran 53mph on the gps.
              I think a leopard 1774kv on 4s or 5s or a a 1400kv on 6s would be awesome. JMO
              - Diesel's Youtube
              - Diesel's Fleet
              • Make-a-Wake
                FE Rules!
                • 6057
                I have admired this motor for quite some time but never had an exact application for it.........I think it would be a perfect fit for the Gen on 6s........its big.....36x88, and apparently highly efficient. It should get the Gen into the mid to high 40's for one bill.
                http://www.offshoreelectrics.com/pro...od=dh-gpmg5325
                But i still like the 1521 setup best, but this is a less expensive alternative that will give good performance.
                • b.mcdaniel.2009
                  • 1872
                  Nice.Thanks for the help!!!
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    With the ammo you could get away with stock mount and possible even the stock jacket.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • b.mcdaniel.2009
                      • 1872
                      what about running the 180amp.turnigy i bought with the stock motor on my genesis.
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        Stock motor will run hot, it's undersized for the hull. You can run it that way until winter hits and then start do a re-build.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          That will certainly work.........ESC will be nice and cool. The stock motor is a semi-amp hog and will run hot due to the high kv. The Ammo i posted above will fit in the stock mount with the stock jacket as Diesel pointed out, will run much cooler and can swing a bigger prop. Its a perfect 6s motor, and like we said, will slide right into the mount and jacket..........plus you already have the beefy 180a ESC to run 6s.
                          • b.mcdaniel.2009
                            • 1872
                            Hell ya you guys are awesome!
                            • Alfa Spirit
                              • 2183
                              Yes, 540XL is too small. May be a Leopard 4074 1400kV or Feigao 580 9L.
