What can possibly go wrong with this set up???
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    -DF-33
    -Neu 1521/1.5D
    -Aquastar 240 Amp ESC
    -octura 447/3 blade prop
    -4S2P
    -all 5.5mm connectors
    -CC bec
    please post few comments
    thanks
    Robert
    Canada
  • Jesse J
    scale FE enthusiast
    • 7818
    I would go with rx pack - the BECs at the amperage/voltage we run seem to be the weak link.
    "Look good doin' it"
    See the fleet
    • RaceMechaniX
      • 3024
      That set-up is similar to a reasonable heat race set-up. Should not have any problems. A X450/3 is also a common P-mono prop. Just make sure you have decent batteries. That set-up with 447 or 450 will pull around 200A, so look for a minimum of 30C and 10000mah total capacity.
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Rumdog
        • 6667
        Run your D wind motor at 0 degrees timing.
          You are good to go for P-mono !
          • LiPo Power
            • 3678
            Can I set up timing to ,,0,, on Aquastar 240 using USB link?
            Canada
            • LiPo Power
              • 3678
              If you think this set up will pull up to 200 Amp should the Aquastar 240 ESC be good enough for the set up? Any concerns on peak amp draw this ESC will not handle?
              Tyler
              Canada
              • LiPo Power
                • 3678
                Is there something you can see in this set up that may burn my motor and take ESC with it?
                Thanks
                Canada
                  • 7512
                  Driver error...........
                  • RaceMechaniX
                    • 3024
                    you will be fine if you use good batteries, and good connectors and start with a 447/3. You must also set the timing to a low value 0-5 degrees as mnetioned above. Adding the Etti cap bank has helped the longevity of mine signifigantly.
                    Tyler Garrard
                    • BakedMopar
                      No Mo Slipah
                      • Sep 2009
                      • 1743
                      Your esc should handle. I run my Rico with that motor with a x450 with a t180 on turnigy 4s2p 4000 40-50c.
                      • TRUCKPULL
                        • 3293
                        Robert
                        That is the same as my "P" Mono race setup - 447/3 prop
                        It will average about 140 AMP's when trimmed right.
                        If you want it to fail let Ray drive it.
                        Larry
                        • Flying Scotsman
                          Fast Electric Adict!
                          • 5195
                          Originally posted by LiPo Power View Post
                          -DF-33
                          -Neu 1521/1.5D
                          -4S2P
                          -CC bec
                          thanks
                          Robert
                          Typical moron question from Ontario wrong prop
                          Douggie
                            • 7512
                            People from BC should never have been given internet access.....
                            Whats frustrating Robert is that this set up ran well all last year and then destroyed itself this year halfway through the season........motor and controller were both fried.......both were replaced and on the first run it destroyed itself again,,,both motor and controller FUBAR'd again!!!
                            And Larry, you are right, Ray would have killed it as well , but with his love of ultra cheap Chinese components, the total failure would have cost about 10 bucks!!!!
                            • LiPo Power
                              • 3678
                              Typical moron quastion and typical moron answer backed up with great help and support...
                              What prop do YOU have in mind?
                              Douggie
                              Canada
