I just bought a new Genesis cat with the 105amp esc and a 2075kv motor. Ill either be running 4s (2,2s packs)and/or 5s pack(1,2c pack&1,3s pack. Anyone know any info on this boat, like lipo esc rating,flex shaft strenth, props? cant wait for it to arive!!!
Genesis cat. questions/comments
Seems a lot of people are going with the seaking 180amp esc and different motors. I got mine with upgraded flexshaft from the seller so it's just a case of undoing the coupler on the motor and pulling the shaft out to grease it. I have also upgraded to the seaking 180amp but still running the standard motor at the mo. The stock esc is worthless imo.
My esc only lasted 3 runs then died!
That would be why then, the yellow one that comes with the HK one and others is pants. I went for the one with the upgraded hardware cos I wanted to run the seaking 180amp esc.Originally posted by HYDROJERRY View PostMine is still running all stock but came with a 120 seaking esc,,,
The stock setup is very light, you must upgade speel controller and motor, 6S setup is ok for good perfs
Motor : LEOPARD 4060/1500KV 4-Poles Inrunner
ESC : Seaking-180A V ersion 2.0
Originally posted by Alfa Spirit View PostThe stock setup is very light, you must upgade speel controller and motor, 6S setup is ok for good perfs
Is this in a Genesis?What kind of mph are you geting with that setup..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
If i wanna hull A#$ in my Genesis cat. what set up does anyone recommend?Nothing that cost over $350 total in motor and esc. ill either run on 4s or 6s lipo's!!I just wanna tear up my pond LOL!!..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
Sorry, I made a mistake. Leopard 4074 1400kv is betterOriginally posted by martin View PostWill that motor be a better choice than a Leopard 4074 1400kv.
Edit : LEOPARD 4082/1500KV 4-Poles Inrunner Brushless Motor LBP4082/2Y
6S + NEU 1521/1Y
Just took the genesis out for the first run stock on 4s the motor got freaking hot its gotta go!It ran good but the boat kept porpusing bad. is that do to the wrong cog or is my strut angle off?????..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
Here's the way mines setup any comments? im looking for suggestions on my prop angle/strut!!..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
