Genesis cat. questions/comments
  • b.mcdaniel.2009
    • 1872
    I just bought a new Genesis cat with the 105amp esc and a 2075kv motor. Ill either be running 4s (2,2s packs)and/or 5s pack(1,2c pack&1,3s pack. Anyone know any info on this boat, like lipo esc rating,flex shaft strenth, props? cant wait for it to arive!!!
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
  • jamespl
    • 748
    Seems a lot of people are going with the seaking 180amp esc and different motors. I got mine with upgraded flexshaft from the seller so it's just a case of undoing the coupler on the motor and pulling the shaft out to grease it. I have also upgraded to the seaking 180amp but still running the standard motor at the mo. The stock esc is worthless imo.
    • Alexgar
      • Aug 2009
      • 3701
      the esc is good for small setups i use one in a 21" ovalmaster with good luck on 6s
      • jamespl
        • 748
        My esc only lasted 3 runs then died!
        • HYDROJERRY
          • Jan 2010
          • 2709
          Mine is still running all stock but came with a 120 seaking esc,,,
          • jamespl
            • 748
            That would be why then, the yellow one that comes with the HK one and others is pants. I went for the one with the upgraded hardware cos I wanted to run the seaking 180amp esc.
            • Alfa Spirit
              • 2183
              The stock setup is very light, you must upgade speel controller and motor, 6S setup is ok for good perfs
              Motor : LEOPARD 4060/1500KV 4-Poles Inrunner
              ESC : Seaking-180A V ersion 2.0
              • martin
                • 2881
                Will that motor be a better choice than a Leopard 4074 1400kv.
                • b.mcdaniel.2009
                  • 1872
                  Is this in a Genesis?What kind of mph are you geting with that setup
                  • b.mcdaniel.2009
                    • 1872
                    If i wanna hull A#$ in my Genesis cat. what set up does anyone recommend?Nothing that cost over $350 total in motor and esc. ill either run on 4s or 6s lipo's!!I just wanna tear up my pond LOL!!
                    • britscoot
                      • 721
                      hahaha when James described the esc as pants i had to check his profile to see if he is British.
                      Haven't heard the term in a while.
                      I'm also from the motherland.
                      Lets go Chelsea!!!!!
                      • Alfa Spirit
                        • 2183
                        Sorry, I made a mistake. Leopard 4074 1400kv is better
                        Edit : LEOPARD 4082/1500KV 4-Poles Inrunner Brushless Motor LBP4082/2Y
                        6S + NEU 1521/1Y
                        • b.mcdaniel.2009
                          • 1872
                          Just took the genesis out for the first run stock on 4s the motor got freaking hot its gotta go!It ran good but the boat kept porpusing bad. is that do to the wrong cog or is my strut angle off?????
                          • video200
                            • 840
                            my guess is that you need to swap the rod from the servo to the rudder to a 4-40. that made all the difference on mine.
                            • b.mcdaniel.2009
                              • 1872
                              Here's the way mines setup any comments? im looking for suggestions on my prop angle/strut!!
