P mono 55+mph set up
  • hazegry
    • Jun 2010
    • 842
    Originally posted by D.Smock View Post
    I run a 1515 1Y, Hydra 240, 4s2p Hyperion 5500 35c cells, and a M445 backcut approx. 1mm in my 31" Rico.
    Tuning for rough water I'll add up to 1 lb. of lead which brings it's weight up to 10 lbs 5 oz. but she finishes races.
    Doug
    Doug are you bringing it to the D12 race in august I will be there and I would love to see the Rico
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1743
      You may also want to check out the MHZ Lizard Extreme and the DF cyberstorm. I have no experience with these though.
      • andym
        More Go Than Show Prop Co
        • 2454
        I love my Seaducer SD3 , carbon electric lay up 1515 1Y and a M447 back cut, bar cut and pitched up. Regulary 55-59 mph racing gassers and that = rough water. I think any of the hulls mentioned will do the job it is all about SET UP end of story !! HP does not mean faster if your set up is off. You need to know how to set it ie; strut depth, correct prop, strut angle and CG for different conditions. No point having a loose set up that will do 60 in wind and boat generated chop. Better off with a boat locked down some and doing low 50's. Same boat calm day and a little chop loosen her up and hang on. So I think a lot of guys chase power at the expense of LEARNING set up.
        • andym
          • 2454
          Oh I refuse to add weight, just change the above to what the conditions dictate
          • hazegry
            • Jun 2010
            • 842
            yeah but you dont race a ferrari with a vw either lol. I understand what your saying about set up.
            • andym
              • 2454
              Put the Ferrari motor in the VW and the VW motor in the ferrari and odds on the ferrari will still win on any circuit with more than two corners !!!!!!
              • T.S.Davis
                • 6266
                I've seen a Scorpion 21 run mid-50s. I run there with my Titan 40 with a Neu 1521/1.5D and 4S2P cells.
                Jay, I built a 33.5" Wildthing around the same setup. Where's a good place to start testing prop wise? M447 until I get it sorted?
                Noisy person
                • hazegry
                  • Jun 2010
                  • 842
                  I was looking on the site here the castle 1515 is only 165 and the neu is 200+ is there much difference? ok I found the answer nevermind
                  • hazegry
                    • Jun 2010
                    • 842
                    The DF cyberstorm looks sweet I might have to pick that one up. I am going to just try to make my Arowana competitive for this season. I might go with the lepord motor ose has or just run a one of these http://www.himodel.com/electric/2075...0_3674-8T.html
                    and a x440 3 blade prop. this is a guy on Rcgroups with the 8t motor and 3 blade x440 set up
                    • BakedMopar
                      No Mo Slipah
                      • Sep 2009
                      • 1743
                      I never realized that my boat (black and white) was on the web page.
                      I agree that setup is key to any boat. All hulls have limits too. They all have strengths and weakness. No matter what you choose. Test, test, test and have fun doing it.
                      • hazegry
                        • Jun 2010
                        • 842
                        well i got a leopard 1515 so we will see what happens I am going to run the hull I have for now get my driving down then look at a new hull over the winter or next spring. Still sourcing batts but should have some soon. any recommendations for a prop other than a m445?
                        • Chilli
                          • 3204
                          Jason, I'm pretty sure Dick lets you guys run what you want in the OD club races but if your planning to run at the district race we have a rule that the P-mono's cant be significantly faster than the nitro guys. It's a consession we made to have the district let us run together.
                          That being said, I run one of Chucks X642's with a 1515 1Y in my Titan 33 and I'm as fast if not a couple mph faster than any B-mono out there. I also run a pound of lead in my boat. Like others mentioned above, once you get her together, do your time at the pond and set that sucker up to run in sloppy water. You definately have a better chance making it to the podium with a boat that finishes all it's heats rather than one thats faster and ends up on it's lid half the time.
                          Mike Chirillo
                          www.capitolrcmodelboats.com
                          • hazegry
                            • Jun 2010
                            • 842
                            Well I doubt this hull will perform as well as your titan33 if it is allot faster I will change props so I can compete in the p class.
                              I started with an x450 but in the loose running mono an x447 would work too.
                              • T.S.Davis
                                • 6266
                                haha Jay, I just noticed your signature. You should add "no matter what your opinion is of them"
                                Noisy person
