Need Help NEU1515/1Y
  • nova68
    • Jul 2008
    • 211
    I could use some help with a motor choice for a Delta Force 29 I have a NEU 1515/1Y I would like use on 4S2P, I am looking for the boat to turn some heads but that might be to much motor or maybe run 3S2P but I don't no if that will work.but I want to stay with a NEU motor and all so I herd that you can run with a 120 amp ESC, can some one please help me with a choice. THANKS
  • Boatman
    • 875
    tHATS what I run in mine with a 642 or s220 or 215 cant remember but the stainless is just over a 642 in diameter. Any larger and it tend to torque roll. GREAT all around setup. Dependable and fast. I also run it with a hydra 240 temps always cool
      • 6057
      I think that is an awesome motor for that boat on 4s....................try a 640 maybe.
      • tth
        • Apr 2008
        • 1600
        The Neu 1515/1y with a X642 on 4s is a "Head Spinner". Definately use a high amp ESC. I have used a Etti 150 with fair results. Whatever ESC you use it wouldn't hurt to add a cap bank. My suggestion would be a Hydra 240.
        • Alexgar
          • Aug 2009
          • 3701
          i run this on 4s is quick 6s insane i use a turingy 180 no problems yet maybe 15 run on this setup
            • 6057
            A Turnigy 180a will do the job.
            • Rumdog
              • 6667
              DO not run 6s on that motor!
              • andym
                More Go Than Show Prop Co
                • 2454
                The motors can handle it, packs and ESC's is another story
                • nova68
                  • Jul 2008
                  • 211
                  1515/1y
                  I would like to thank every one for there help. I am going to run the NEU 1515/1Y in my DF 29 it should be fast on 4S2P.
                  • Alexgar
                    • Aug 2009
                    • 3701
                    642 for sure on 4s on 6 s diasater but quick for about 10 min
                    • Alexgar
                      • Aug 2009
                      • 3701
                      torque roll and blow over the torque is obsene
                      • Alexgar
                        • Aug 2009
                        • 3701
                        was thinking of a 645 just for fun saw whatever that is (fast)
                        • Boatman
                          • 875
                          I have to admit I have been very tempted to hook up a 6S pack with a 440 and see what happens. I can only imagine it would be stupid fast. I DID once hook up 6S to a 8XL in a SV27 and it was infact stupid fast but as Andy stated the esc gave out after about 2 minutes of runtime.
                          • nova68
                            • Jul 2008
                            • 211
                            Neu 1515/1y
                            I for got to ask what size aluminum turn fins to use, the ose-80062 medium or ose-80066 large ?
                            • m4a1usr
                              Fast Electric Addict
                              • 2036
                              You could get by with the 80062 but for a small hull like that your probably better off with the 80060. Remember you dont want either turn fin in the water on plane, that only contributes to drag. They are only needed in a turn.
                              John
                              Change is the one Constant
