I could use some help with a motor choice for a Delta Force 29 I have a NEU 1515/1Y I would like use on 4S2P, I am looking for the boat to turn some heads but that might be to much motor or maybe run 3S2P but I don't no if that will work.but I want to stay with a NEU motor and all so I herd that you can run with a 120 amp ESC, can some one please help me with a choice. THANKS
Need Help NEU1515/1Y
I think that is an awesome motor for that boat on 4s....................try a 640 maybe.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
The Neu 1515/1y with a X642 on 4s is a "Head Spinner". Definately use a high amp ESC. I have used a Etti 150 with fair results. Whatever ESC you use it wouldn't hurt to add a cap bank. My suggestion would be a Hydra 240.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *
A Turnigy 180a will do the job.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I have to admit I have been very tempted to hook up a 6S pack with a 440 and see what happens. I can only imagine it would be stupid fast. I DID once hook up 6S to a 8XL in a SV27 and it was infact stupid fast but as Andy stated the esc gave out after about 2 minutes of runtime.
You could get by with the 80062 but for a small hull like that your probably better off with the 80060. Remember you dont want either turn fin in the water on plane, that only contributes to drag. They are only needed in a turn.
JohnChange is the one Constant
