Genesis cat,,,
  • HYDROJERRY
    • Jan 2010
    • 2503
    #256
    I'll take some pics in a while,,,didnt get to charge my batts cuz last night had my wife's little brother's football game to got to so couldnt charge up but hopeing to get wet tomorrow morrning..
    • HYDROJERRY
      • Jan 2010
      • 2503
      #257
      Sorry about the double post dont no what happend,,Anyway hears those pics of the strut and such,,,
      • Diesel6401
        Memento Vivere
        • 4203
        #258
        Just hold a papertowel by the end of the stuffing tube give a quick blast of the throttle and the excess grease will fling into the tissue instead of in the hull and on the roof of the cowl Making sure the papertowl can't get wrapped in the collet or flexshaft of couse. I never tried it, jsut was sitting here and it popped in my head. I normally end up with a grease fling feast in my boat as well I just clean it when I'm done running.
        - Diesel's Youtube
        - Diesel's Fleet
        • HYDROJERRY
          • Jan 2010
          • 2503
          #259
          yeah ok Deisel i gatcha...
          • HYDROJERRY
            • Jan 2010
            • 2503
            #260
            Me and chud got some runs in today,, my genesis and his sv27 it was fun, got there alittle late so the boaters were just getting going,,GPS'ed the genesis and it showed 61.9mph and a average speed of 29.8mph i dont think that was right but the skies were clear so i dont no whats going on there,, but chuds newused sv27 hull with the new UL-1 motor and esc he bault from me ran great and very cool and very fast,, he flipped it a few times but landed right side up so kept going ,,,,got vids hopefully get them on later or tomorrow...Hope everyone else had a good day...Ps ran my miss elam also but flipped in the first straight away and had to swim for it so no good there...
            • HYDROJERRY
              • Jan 2010
              • 2503
              #261
              Well my brother and i ran alittle this morning and as always my Genesis ran great was chasing my brother's sv27 but then he flipped it,,this is becoming a normal thing for him and the flip nocked off his antanna tube so he came in and stuck it back on then went back out and dyed in the middle so i had to swim for it, so didnt figure out whats wrong with it so we moved to my new(used) sv27 and mine would not arm???? tryed 3 times and only the rudder would work so then back to my Genesis cuz we had to kill all the batts and again she screamed,,,will play with the sv's later and try to find out whats wrong and go again tomorrow...
              • HYDROJERRY
                • Jan 2010
                • 2503
                #262
                Ran mine today and she ran great until i flipped her and the pin that goes in the top of the rudder bracket came out no its lost and i cant hook the rudder back on,,,,,
                Does anyone no where i can get an replacement for it????
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  #263
                  PM sent
                  • HYDROJERRY
                    • Jan 2010
                    • 2503
                    #264
                    Good call man thanks for the offer, think i got it...
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #265
                      Cool.
                      • sailr
                        • Nov 2007
                        • 6924
                        #266
                        probably a 3mm pin. Go to NAPA auto parts and buy a 3mm drill bit, cut it off and use it.
                        Mini Cat Racing USA
                        www.minicatracingusa.com
                        • Alfa Spirit
                          • 2131
                          #267
                          Now I' m building the HOTR catamaran, setup is 6S with FSD 1500kV motor, 540XL size
                          I' m waiting for 2 x NEU Motors 1512 1,5Y 1850kV with water jackets from Steven and other parts
                          @ Mudl: you' ve got a private message
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            #268
                            Cool thanks Sailr, ill do that,,
                            Alfa whats up,,i thought you already got you Genesis going huuummm..
                            • sailr
                              • Nov 2007
                              • 6924
                              #269
                              Be sure to double check the diameter of that pin before buying the drill bit. Or...take the rudder with you and check it at the store. Don't take my word for it!
                              Mini Cat Racing USA
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                #270
                                Hey sailr i went and couldnt find a 3mm bit so i found one as close as i could, did it up and now it holds i cut a little notch for the set screw to bite in,,,,and i also took out the motor removed the rear cap end and drilled holes in it to help with my heat issue will show a pic tonight...PS good idea man on the bit!!!!
