New Hobby King Cat (Surge Crusher)
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    #211
    Originally posted by hpipro4 View Post
    not with my new setup. still need to go test it out. but heres old setup:
    really?? because it works just fine! incase you didnt know the whole drive system is modded and shaft rides on ceramic bearing. there is a gap but aint much but its there.
    Well, I will be rude that is a recipe for disaster on the photos posted, that I viewed and posted on...especially at the motor connection, as previously stated. Shaft or flex drive a huge difference? The pictures look like flex. If it is a shaft it is OK but not the best drive system. That pond is also a recipe for disaster...WEEDS and way too short
    Douggie
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      #212
      Originally posted by Flying Scotsman View Post
      Laddie, you have some real problems with the drivetrain, your bare flex drive connection at the motor is way too long prior to the stuffing tube and you left no clearance between the drivedog and the strut. My 2 cents.
      Douggie
      Douggie- the coupler is a square-slip, making the drive a two piece setup. There's a step up on the hard prop shaft in the strut, the prop dog should be snug up to the strut, no gap, on this setup. If there is a gap, the shaft will fill with water and leak inside the hull.
      When the cable contracts in this setup, it simply moves in and out of the coupler. This is quite an unusual setup from the factory.
      HTH
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        #213
        Here, these should explain;
        In the first photo, notice the step up in the hard prop shaft. It's slight, but keeps the shaft captive in the strut as shown in the last photo.
        There is only 1 set screw in the coupler, on the motor side.
        • Flying Scotsman
          • 5195
          #214
          That is a weird setup but thanks for showing the design. I just stumbled onto this thread and saw your photos and went what the hell is that and did not read the whole thread.
          Thanks,
          Douggie
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #215
            Thanks,
            Douggie
            No worries. It is indeed an odd setup. All of the "joys way"scheiße boots use this configuration.
            BTW- the extra fiberglass around the motor mount prevents the hull from cracking and is holding up well. It just need a little stiffness.
            • Linksu79
              • Jun 2010
              • 4
              #216
              My Surge crusher video http://www.youtube.com/watch?v=Mr3mmmL_1F8
              • GTX
                • 9
                #217
                Anyone have the Super version yet ? I wonder if the motor mount is more secure on the super version to prevent the hull cracking ?
                • Linksu79
                  • Jun 2010
                  • 4
                  #218
                  My Surge Crusher picture.
                  • Linksu79
                    • Jun 2010
                    • 4
                    #219
                    New Speed record 102km/h / 63,4mph
                    Motor Turnigy H500 1800Kv
                    Specifications:
                    Dimension: 37mm x 50mm, 71mm(with shaft)
                    Weight: 170g*!**
                    Kv:*!**1800rpm/V
                    Voltage: 3-6S
                    Max current: 55A
                    Diameter of shaft: 5mm
                    Length of front shaft: 20mm
                    ESC: 65A
                    Esc Turnigy marine 180a
                    Constant Current: 180A
                    Burst Current: 360A
                    Resistance: .0007ohm
                    Battery: 2-6S Lipoly
                    BEC: 5.8v/ 3A
                    Motor Type: Sensorless Brushless
                    Size:*!**72 x*!**68 x 34mm
                    Weight: 165g
                    Prop Grimracer 40x57/3
                    Battery 2x Turnigy 3s 30-40c 5000Ma Lipo
                    Power 2951W/133Ah
                    Max speed 102km/h
                    63,4mph
                    • maxmekker
                      • 466
                      #220
                      Wow
                      Drammen rock City
                      • Graeme
                        • Jun 2010
                        • 97
                        #221
                        Nice combo looks great did you reinforce the hull around motor mount ?
                        • hpipro4
                          • 65
                          #222
                          hey Linksu79,
                          pretty cool build! this the motor your running? http://hobbyking.com/hobbycity/store...idproduct=9258
                          those motor mounts frm r2hobbies?
                          are you running the wire drive system?
                          the tabs actually helps?
                          • Linksu79
                            • Jun 2010
                            • 4
                            #223
                            hey Linksu79,
                            Hello!
                            This motor mount http://www.r2hobbies.com/eng/proddet...od=rcbp1814011
                            Hull arment 4 layers glassfiber motor mount under
                            Same motor! Motor temp abaut 50-60 celsius / 122-140 farenheint
                            3/16 flex drive
                            Yes trim tabs stabilize.
                            sorry bad english
                            • maxmekker
                              • 466
                              #224
                              looks good, I will get mine in a couple of weeks, looks like a good buy.
                              Drammen rock City
                              • Jacked1
                                • Jun 2010
                                • 787
                                #225
                                So you pulled 130 amps on that motor?
                                if it is good i might go with 2 of the 1100kv version of the same motor in a mean machine.
