Regular TP4060 on 50K RPM
  • Ivan Kozyakov
    • Apr 2022
    • 112
    Hi guys!
    Next season, I'm planning to upgrade my SAW outrigger setup to a TP4060 2000kv with 8s. Theoretical RPM under load is 50-55000 (this is higher than the passport 50K RPM). Will a standard (regular) rotor handle that kind of RPM? Or do I really need the SVM series?
    I already have a standard TP4060 1750kv with 8s (45-50,000 RPM by telemetry ) running without any problems and I like it.
    I'm wary of the SVM series with its solid rotor due to its fragility.
    I'd be grateful for your experience and advice.
  • vvviivvv
    • 1100
    What is the speed goal? im on a tp 2300KV & 6s. standard TP motor. 45mm 3 blade prop.
    Uk SAW record holder
    • koen
      • Mar 2020
      • 366
      for boats a TP regular is best ,the CM SVM are car motors max rpm only 10 sec
      • Ivan Kozyakov
        • Apr 2022
        • 112
        The current result is 172 km/h, next season with an updated motor, props and sponsons I plan to reach 200 km/h.
        • Ivan Kozyakov
          • Apr 2022
          • 112
          I think so too, but the manufacturer specifies a maximum of 50,000 RPM. I wonder if anyone has exceeded that maximum.
          • vvviivvv
            • 1100
            Yes, plenty have
            koen, a SAW pass is basically 10 seconds if that.
            Search the threads for tyler's explanation of the TP motors and that will help with deciding.
            • vvviivvv
              • 1100
              Ivan i have sent you some pics of the SAW boat
              Is yours anything like as long ? 1.5m Hpr150 on top, 1.9m H185 mid shelf.
              • Ivan Kozyakov
                • Apr 2022
                • 112
                Yes, I received it. Thank you, very interesting.
                I'm not much of a fan of big boats and catamarans; I sold all my models. My passion is outriggers.
                • vvviivvv
                  • 1100
                  I was more curious about the design of your rigger, is it somewhat similar to mine?
                  • Ivan Kozyakov
                    • Apr 2022
                    • 112
                    My rigger is based on a Dr. Super Evil hull and has selfmade SAW sponsons that are fundamentally similar to your boat. When I finish making them, I'll make a new post on this topic.
                    • leski379
                      • Jul 2023
                      • 99
                      Originally posted by Ivan Kozyakov View Post
                      Hi guys!
                      I just scattered a rotor in my TP4050 2100kv regular on 8s. Made 3 awesome runs before it happened though.
                      • Ivan Kozyakov
                        • Apr 2022
                        • 112
                        This is a alarming sign. Did you have RPM telemetry? Did the ESC survive? Please tell more about your setup.
                        • leski379
                          • Jul 2023
                          • 99
                          Logging was unfortunately full! It would have been really cool to see that event on a data log.
                          XLX2 survived no problem this time.
                          This was on my 34'' mono on 8s
                          • Ivan Kozyakov
                            • Apr 2022
                            • 112
                            I also use a XLX2 Hydra and I'm counting on its protection to protect me from rotor failure. Have you had any other experiences with rotor failure using this ESC?
                            • leski379
                              • Jul 2023
                              • 99
                              I cooked a 4090cm rotor from heat but that was my bad. Thats it so far. (you can't buy just a rotor for a 4090cm by the way lol)
                              What protections are you counting on? Do you have a sensored motor?
