I can't get my teflon tube for .130 cable into the 7/32 brass tube I have. How the hell do I get it in there? It wont budge.
Stuffing tube help needed
Are you sure it's a 7/32 tube? Are you sure it's a 0.130? Mine all fit a bit loose"A quick temper will make a fool of you soon enough."
7/32 is like .21 something. I dont have a chart in front of me right now. You must be using 5/32? Normal teflon line should slide right in like Diego said in 5/32 tubing. I wonder if you got an odd size teflon?
JohnChange is the one Constant
you might measure the od of your teflon and id of brass with calipers to help understand how much we are talking - Jeff's point is good, sometimes the teflon is juuuuusst a hair big and stretching it actually decreases the diameter."Look good doin' it"
See the fleet
I have even run sand paper down it to remove a few .000
Tight is good! I have seen some want to actually spin in the stuffing tube.
That brass tubing id is too small if true. I measured my stock and its .191 id and the octura OC130L-24C .130 flex/teflon combo slides right in my tubing.Originally posted by boater76 View PostMeasured od of teflon was about .183 and the brass id was bout 5mm or 1.79
:canada
