Turginy balance connectors
  • Flyguy55
    • 218
    Do Turginy balance connectors match with Hyperion chargers with out adaptors ?
  • sailr
    • Nov 2007
    • 7128
    Gawd only knows. I wish they would standardize the danged balance connectors!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • lectriglide
      • 540
      I'm pretty sure they don't.
      http://www.allerc.com/product_info.p...oducts_id=3159
      Turnigy uses a JST-XH balance connector. Looks like you need the HP-LB10-XH balance adapter.
      • Diesel6401
        Memento Vivere
        • 4391
        That's what I needed to buy for my hyperion charger, except I purchased mine from rcaccessories.com same part number and looks like it's about $1 cheaper from allerc though.
        - Diesel's Youtube
        - Diesel's Fleet
        • Rumdog
          • 6667
          Turnigy's are the same as MOST lipos.
          • JimClark
            • 5913
            There are only 4 or 5 different types.
            If you have hyperion charger now you should be able to get an adaptor that would go from the JSTXH to the hyperion from hobbycity. i got some 2s adapters for my small zippy's
            Jim
            Billy Graham
            • scooterP
              • Jul 2009
              • 250
              I think that they will hook directly to your hyperion charger. I have an Bantam BC8 and the adapter that I use to charge Turnigy 2s packs in series is designated for "Hyperion and Polyquest".
              • Flyguy55
                • 218
                Thanks everyone for the input . Looks like yes , no , maybe . Anyone have any first hand experience ?
                • JimClark
                  • 5913
                  Turnigys have the JST-XH balance tap
                  Hyperion uses a different one you need an adaptor or a JST-XH balance board for your charger
                  Like it was said above in post #3 you need a Hyperion HP-LB10-XH balance board these other guys that say they will are totally off base and yo are gonna screw up your batteries
                  Billy Graham
                  • scooterP
                    • Jul 2009
                    • 250
                    I am so sorry. Here I was talking out of my arse again. I got my balancing adapters mixed up. I use a couple of different ones.
                    It appears that you use the adapter for align. This is the board that I use with my Turningy 2s packs.
                    I hope this helps.
                    • detox
                      • 2357
                      This is the one I use with my Turnigy lipos and Hyperion 606 charger. I purchased this XH version from ALL E RC when I purchased my charger.
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        I bought this last week. I did use the one detox posted before. I hooked it up 2 2s zippy's and set the charger to 4s. Everything checked good and began to charge at 4amps, but I only let it charge for about 3 minutes to verify it worked. Haven't used it since I've been out of town alot lately, but it appears to be a good $6 investment. Nice part it comes with several different balance plugs for different chargers. It works on hyperion, but did not fit my Triton.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Himalaya
                          • Apr 2009
                          • 259
                          for 4S and above, yes, they are compatible.
                          for 3S and below, just change the adapter board.
                          • Flyguy55
                            • 218
                            Thanks , I ordered the correct adaptors from ALL E RC today
