I have a 30 inch SAW hydro that lost power. I was almost at the end of chaseing problems when it took a terrible tumble. I made repairs on some cracks in the hull and now its a slug. Boat was doing well and creeping up on some fast numbers. I was in the 96-100 mph area and now i can not get past 70mph. Data logger shows normal voltage drops and temperatures. My motor RPM on logger is very high and aratic even though boat is not anywhere near these rpms it shows.Also it sucks down batteries very fast like never before. They are thunder power 21 volt 45-90c 5000mah and brand new. Castle creations says its not the controller because its either on or off and wont pull out power. Combo is Hydra 240HV, NEU 1527 and a m645 prop. Could the motor have lost its grunt. Its got very little time on it. I have swapped radios and recivers and checked all programing on Hydra.Any ideas?
Lost my power
I may have worded this wrong. I have 2 11.1 volt 45-90c 5000mah thunder powers for 25 volts fully charged. At 98 mph ,back to back runs that i saved , it was turning 41,600 so im below what they can handle. The motor feels the same turning it by hand . Should it spin real easy if the mags go?PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mph
You will know if the magnets become weak from heat damage on a Neu. At least if you pay a little attention to your motor. If the cogging or "clunk" whatever you want to call it has less strength and if you have a decent "herd" or fleet of motors then you can compare it. So if your Neu spins very easily then chances are its damaged. I bought a used Neu off B-tray and knew right away it was damaged. There was very weak cogging when spinning by hand. Sure sign. Neu confirmed it for me after I sent it in.Originally posted by Gary View PostThe motor feels the same turning it by hand . Should it spin real easy if the mags go?
You stated that there were some cracks in the hull needing repairs? Have you carefully inspected the sponsons, ride pads, transom since the repairs? When set on a flat surface are the angles true? Take a 24 to 36" straight edge and compare the bottom both front to back and diagonally. Your issue might be with the hull and not the electronics.
JohnChange is the one Constant
Is the prop bent out of shape from the tumble, that could account for a lack of speed and increased amp draw.Paul Upton-Taylor, Greased Weasel Racing.
I had a P mono and OPC tunnel that mysteriously lost power. I tested the batteries every way possible. Somebody suggested I try different batteries. DAMN! That was it. Although the batts seemed to be just fine, they had just plain lost their punch.Mini Cat Racing USA
www.minicatracingusa.com
Native paul..I did ding the prop and swap it but i have 4 exact props in stock so they are all the same. I guess i will change the batteries and see what happens. The pair that i run my fast times with are almost new but i only have 1 pair of these particular batteries. They where 300.00 so i only bought 2 for now. I will try that Sailr. It would make sense because the batts dont last 2 runs now and power falls off fast on the second run and it has never done that. Like i said 2 back to back runs before at 98 and now barely can touch 70 and battery voltage dosent drop to less 24 volts during runs.PT-45, 109mph, finally gave up after last bad crash
Chris Craft 16 mph
Ok just came back from lake. Boat went a 78 on my same batteries and than a 76 on brand new thunder powers, still way off the mark but i now know its not the batteries. Motor still feels ok but its got to be the problem. I am going to send it back to NEU Friday morning and hope he tells me something is wrong.PT-45, 109mph, finally gave up after last bad crash
Chris Craft 16 mph
Good to eliminate one possible source anyway. I think sending it back to Steve Neu is your best bet at this point. Let us know what the problem was.Mini Cat Racing USA
No the boat runs perfect there is just no power or rpm. I could see 5-10 mph with something off but 30-35 mph is extreme. I will wait and see what Steve Neu says. I shipped it back today. I will keep you filled in Sailr. I have spare everything ECCEPT motors.I almost never have a problem with any i have used. I needed a break from it anyhow so this is good i think.Last edited by Gary; 03-19-2010, 08:22 PM.PT-45, 109mph, finally gave up after last bad crash
Chris Craft 16 mph
Ok Neu called and said motor is 100 % perfect.................. Castle is telling me the ESC is an on off device and that it wont hold back power. Before i waist more time shipping this stuff back and forth do yo guys think thats possible? Its a 240HV. Remember its really useing up the batteries ............two passes is almost impossible so thats why i figured it was the motor.Any last ditch ideas before i ship the ESC out? Thanks Guys.PT-45, 109mph, finally gave up after last bad crash
Chris Craft 16 mph
