OPC Tunnel Boat
  • bigwaveohs
    • 606
    OPC Tunnel Boat
    I'm looking for an OPC tunnel boat. So far it seems to be either an 0.21 nitro hull or the Bandit II which has been problematic. Any suggestions?
    I let the dogs out...
  • Hydromaniac
    • Oct 2007
    • 955
    Are you wanting to do an electric conversion or run nitro?
    www.rockymountainthunderboats.org
    • sailr
      • Nov 2007
      • 7128
      The aeromarine predator .21 is a nice hull and runs great. That is what I'm racing in SPEC OPC Tunnel.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • HOTWATER
        • 2419
        I agree with you sailr. I have two of the .21 Pedator tunnels and they are very solid performers. I have one that I run with a stock K&B .21 motor and the other has a modified .21 K&B with a Gardner exhaust throttle and a Garcia pipe...I also extended the motor mount on this one 1 1/2" back on the transom to give me an added 5 to 10 MPH increase in speed (a great tip from Remmy of Aeromarine Laminates) and it flies!
        I have often thought about converting one of these tunnels to brushless...
        -Kent
        "Will race for cookies!"
        IMPBA D12
        • sailr
          • Nov 2007
          • 7128
          I bought an extended mount from Technology Hobbies and pushed mine back 1.5" too!
          Mini Cat Racing USA
          • HOTWATER
            • 2419
            I took the black peice off of the Dubro mount and had a freind of mine machine a new one out of aluminum...just a duplication but 1 1/2" longer. When the pipe turned on with this setup, the boat was very scary fast!!
            -Kent
            IMPBA D12
            • RandyatBBY
              • 3944
              I make a 27 inch tunnel in FG, CF and ABS
              Randy
              BBY Racing
              • Ub Hauled
                • Aug 2007
                • 3051
                International Waters has 2 threads with some very nice looking Tunnels... you should chk it out.
                • eboat
                  • Aug 2007
                  • 726
                  How does moving the motor and leg back an extra 1 1/2 " make it go faster ?
                  • Ub Hauled
                    • Aug 2007
                    • 3051
                    lessens the angle of attack, helps it stay in the water, you can make it loser and get away with it.
