I'm looking for an OPC tunnel boat. So far it seems to be either an 0.21 nitro hull or the Bandit II which has been problematic. Any suggestions?
OPC Tunnel Boat
Tags: None
The aeromarine predator .21 is a nice hull and runs great. That is what I'm racing in SPEC OPC Tunnel.Mini Cat Racing USA
www.minicatracingusa.com
I agree with you sailr. I have two of the .21 Pedator tunnels and they are very solid performers. I have one that I run with a stock K&B .21 motor and the other has a modified .21 K&B with a Gardner exhaust throttle and a Garcia pipe...I also extended the motor mount on this one 1 1/2" back on the transom to give me an added 5 to 10 MPH increase in speed (a great tip from Remmy of Aeromarine Laminates) and it flies!Originally posted by sailr View PostThe aeromarine predator .21 is a nice hull and runs great. That is what I'm racing in SPEC OPC Tunnel.
I have often thought about converting one of these tunnels to brushless...
-Kent
I bought an extended mount from Technology Hobbies and pushed mine back 1.5" too!Mini Cat Racing USA
I took the black peice off of the Dubro mount and had a freind of mine machine a new one out of aluminum...just a duplication but 1 1/2" longer. When the pipe turned on with this setup, the boat was very scary fast!!Originally posted by sailr View PostI bought an extended mount from Technology Hobbies and pushed mine back 1.5" too!
-Kent
I make a 27 inch tunnel in FG, CF and ABS
International Waters has 2 threads with some very nice looking Tunnels... you should chk it out.Originally posted by bigwaveohs View PostI'm looking for an OPC tunnel boat. So far it seems to be either an 0.21 nitro hull or the Bandit II which has been problematic. Any suggestions?:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
