I need Shockwave 26 help
  • Maggster
    • 41
    Hey guys I just got a Shockwave 26 and a Mini-V used. The guy I got them from had converted the SW26 to straight drive (no strudder) and I put a 40.5mm Graupner carbon prop on it. When we went out to run them, the completely stock Mini-V is much faster the SW26. Now I am new to boats, but it seemed like I could definitely tell when the MV stepped up on plane, but couldn't tell any similar step on the SW. It looks like the nose is being pushed down into the water. Any ideas? I looks to me like the prop comes out at a pretty steep downward angle. Basically, I think he just pulled the tube from the strudder out and put the new one in its place. It is stock except for the straight shaft. Running IB4200 6-cell in the SW and IB1400 in the MV.
    I have to leave for work shortly, but I'll try to get pics and maybe a video tonight.
    Thanks
  • saleens7
    • 1130
    the reason the nose is being pushed down in the water is because the shaft is at such a downward angle...that mini v is pretty quick too....the SW36 is kind of slow unless you upgrade it....
    saleens7, the wookie of rc boating
    • Maggster
      • 41
      What is the solution? Should I switch back to the strudder or should I look at cutting the bottom of the hull where the prop exits and running the shaft out of the bottom of the V?
      As fas as upgrading goes, I would like to keep the stock esc, but I was thinking of a 600 motor.
      Thanks for the reply
      • saleens7
        • 1130
        i think you should just put the strudder back on....you can upgrade to a 600....i did with mine (and a larger prop....the one on it right now should be good) and it did increase in speed 2-3mph....
        • Maggster
          • 41
          The prop is a 4mm Graupner carbon. If I understand right it won't fit directly on the strudder setup, but I'll look at it when I get home.
          Thanks for the advise, I sure need it.
          • saleens7
            • 1130
            wait, is it using a 4mm solid shaft? if your willing to, you could pull the shaft (and stuffing tube) out and buy a 1/8" to 4mm flex coupler so you can re-install the shaft so it hase less of a downward angle.....
            • Maggster
              • 41
              Please understand that I am new to all of this, but it looks like it has a flexible coupler that is about 1-1/2"long between the motor and the shaft that the prop is on. Is that what you mean?
              • saleens7
                • 1130
                this is what a flex coupler would look like
                it has a peice of flex shaft between where it hooks on to the motor shaft and prop shaft
                • Maggster
                  • 41
                  Yes it looks exactly like that.
                  So what would I need to do? Just redrill a hole for the tube so that it exits a little higher?
                  • saleens7
                    • 1130
                    actually i would try to make the propshaft comes out more parallel to the bottom of the hull....so it wont come out through where the origonal propshaft did, but out of the transom....that way you can keep the motor in the same position.....
                    • Steven Vaccaro
                      Administrator
                      • 8932
                      Is there a way for you to post a picture of the transom and interior?
                      Steven Vaccaro
                      • Diegoboy
                        • Mar 2007
                        • 7443
                        Worth 1000 words!!
                        • Maggster
                          • 41
                          I am finally home from work. I have the boat ready and there is a lake about 5 minutes away. I am going to try to take some pics and video. Be back shortly.
                          Thanks
                          • Maggster
                            • 41
                            Here are some pics and a crappy video.
                            VIDEO
                            • saleens7
                              • 1130
                              i cant really tell how it would ride up on the nose...your in a turn the whole vid......could you take a vid longer that 5 seconds?
                              seeing how the propshaft comes out, it is definately at too negative of an angle....i would remove the shaft and stuffing tube (the stuffing tube probably wont survive though) and cut a hole on the bottom of the transom and have the shaft exit there....are you using a 1/8" shaft? if so, how do you use a 4mm threaded prop and coupler....i can only find a 1.8: to 4mm coupler. but not a 1/8" to 1/8" one.....
