typical wiring in parallel
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3186
    #46
    Thanks Doug.
    I will research this on my own a little bit more, thats for sure.
    Your Idea with wires is perfect and as someone said very clean, just like all you do in your boats. Thanks for help. That is what forums should be all about so new people like myself can exchance info with pro boaters like Doby and You.
    Robert
    Canada
    • Joe Ford
      • Apr 2008
      • 101
      #47
      Originally posted by bustitup View Post
      ok I have two 6s 5000 mah packs and i want to run 6s2p
      I was told by castle tech today that I cant just seperate the dbl bat leads on a hydra 240 and seperate them so I end up with two posatives and two negatives then plug eack 6s into its own set of wire leads
      bottom line is you cant seperate the dble leads on a esc....... so says castle?
      is this true?
      This IS true.
      Joe Ford
      Product Specialist/Surface Team Manager
      Castle Creations
        • 7277
        #48
        Perhaps clearing this up in the supplied instructions might reduce damaged controllers and warrenty repair/replacements.
        • LiPo Power
          • 3186
          #49
          Originally posted by Joe Ford View Post
          This IS true.
          I have done one more experiment here on the picture showing that is safe to run 2 bats beeing connected to their own cables going in to ESC without any issues for xSxP configuration.
          Cheers
          Robert
          Canada
          • LiPo Power
            • 3186
            #50
            Hey Doby, our Deltas are fine .....
            Canada
            • Doug Smock
              • 5264
              #51
              I was told by castle tech today that I can't just seperate the dbl bat leads on a hydra 240 and seperate them so I end up with two posatives and two negatives then plug eack 6s into its own set of wire leads
              bottom line is you can't seperate the dble leads on a esc....... so says castle?
              is this true?
              This IS true.
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
