typical wiring in parallel
  • Doug Smock
    • 5264
    Glad I could help, thanks guys.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • teach
      • 509
      Originally posted by D.Smock View Post
      Here ya go Nick.
      Sorry for the dark pics, I'm no Jim Clark.
      Doug
      Sorry way OT but ya....that guy snaps amazing pictures!!
      • FloatDaBoat
        Bare Bones Fabricator
        • Sep 2009
        • 368
        I've used 20 gauge Magnet (motor rewind) wire to secure wires together for soldering. The solder won't stick to it, & can be removed afterwards, leaving a less bulky connection for a shrink tube insulation covering. I still prefer using a sleeve made from brass tubing, though. Tried to include a photo, but the download failed.
        • bustitup
          • 3071
          Here ya go Nick.
          I bind the wires together with 18 ga. solid strand copper wire then solder them with a good hot iron. Get the job done and get out.
          If you need the wires to bend back over the control as I did in this case, keep that in mind before you strip and solder them. Make sure all the wires are the same length before you start.
          Hope this helps.
          Doug
          so now if i have this right..if i want to run 6s1p I would just take one of my 6s lipos and wire it to one set of red and black on the esc and leave the other set of black and red unhooked (but protected)?
          and for 6s2p I would take my two 6s lipos and wire each separate packs to there own red and black leads off the esc
          and for 12s1p I would take my two 6s lipos and wire them in series and then hook them to one set of the black and red off the esc and leave the other set of red and black not wired to anything (but protected)
          this is all correct after I make the wire mod that Doug shows above
          have i got it?
          • bustitup
            • 3071
            email it to me and i will post it
            nickwild@comcast.net
            • FloatDaBoat
              • Sep 2009
              • 368
              Sent the photo Nick, you may not receive it though, as I'm having puter problems on my end.
              • bustitup
                • 3071
                got it
                • arnie84
                  • 236
                  thanks for the info & pictures this thread has been great help to me also!!
                  • Jeff Wohlt
                    • 2716
                    Mechanical connection is the way to go with the wire wrap. It could save folks from coming unsoldered and maybe save the ESC or cells and get back in.
                    How many time have we heard it came unsoldered.
                    www.rcraceboat.com
                    jwohlt5362@yahoo.com
                      • 7277
                      OK,,,Stupid question, why can't you just separate them. I have mine hooked up that way for the past 2 years with no issues?????
                      I don't recall seeing anything in Castles instructions either?? Maybe I'll have to go and re-read them!
                      • arnie84
                        • 236
                        Im about to do it tonight, so if anyone can post why you just cant run the wires seperated pos & neg going to each battery not connected together like in the picture above would be great
                        • LiPo Power
                          DJI Drone Advanced Pilot
                          • 3186
                          Same here Doby. I was running this boat like that for the season and no issues at all. This is 4S2P. It was installed before I got this boat by the previous owner. They had this set up running for a while also with no issues.
                          Robert
                          Canada
                          • Doug Smock
                            • 5264
                            Hey Fellas,
                            Page 1 Castle Hydra instructions.
                            "Make sure and connect the entire battery pack to both input wire sets of the Hydra 240.
                            Do not connect half of the battery pack to one input, this will lead to operating problems from potential voltage / current imbalances."
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                              • 7277
                              Could be taken also as connect one set of pos and negs to one battery and the other set to the other battery. As long as you run with both sets connected you will be OK, If you only run with one battery connected, then there could be issues.
                              Castles instructions are a bit ambiguous on this matter.
                              Joe Ford, where are you !!!!!!!
                              • bustitup
                                • 3071
                                I allready asked Joe ford and castle tech also....they both will tell you what D. Smock just told you
                                DO NOT RUN WITH THE DOUBLE LEADS SEPERATED!!
