Rudder Trailing Edge.
    All this effort expended trying to re-invent the wheel - again......
    High-speed surfacing rudders are wedge-shaped because that causes the least amount of drag. The water off each side of the rudder stays apart - you do not want it to come back together too soon. Air travels down the back face of the rudder to fill the void left behind the blade - this requires much less energy than trying to move water to fill the void because air weighs less and moves around turns much more easily. More energy wasted means more drag and lower speeds.
    Sharp, airfoil-shaped training edges are terrible, promoting occilations of the rudder and resulting in wandering on the straights. Wedge shaped rudders promote better turning like wedge-shaped prop blades do, creating low pressure on the turning edge to help bring the transom around. This is all well-proven technology in both full-scale and model applications.
    You simply cannot apply the technology from slow-moving displacement sailboats to surface-planing racing powerboats. The rudders are different (as is the surface finish of the boat bottom. Furniture wax is certainly not where it's at for a "speed coat.")
    Believe me, if airfoil-shaped rudders were better, the Budweiser Unlimited team would have used that technology. But they used wedge-shaped rudders and turnfins. They didn't wax the bottom of their boats either. While thinking outside the box is good for some things, others based on basic physics just can't be improved. Now when we go to fuel-cell technology and race at 150 mph we may have to do some things differently - but I bet it won't include airfoil-shaped rudders.
    • sailr
      • Nov 2007
      • 7128
      yada yada yada. One eveything bagel with chives cream cheese please.
      That's as technical as I like to get.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • teach
        • 509
        No bacon bits?.....weirdo
        • Ub Hauled
          • Aug 2007
          • 3051
          Not from my part, I am just trying to understand where people a coming from when they say "wedge is better", the "why" of things.
          Thanks for the explanation though, I have looked around and found little on this matter.
          • sailr
            • Nov 2007
            • 7128
            Personally, I've never enjoyed a wedgie.
            Mini Cat Racing USA
            • sailr
              • Nov 2007
              • 7128
              Naw, I like to keep it simple. Good thought though!
              Mini Cat Racing USA
              • Ub Hauled
                • Aug 2007
                • 3051
                In one word... "commando".
                • jantagg
                  • 229
                  Following the advent of surface propellers and three point hydroplanes, foil or teardrop shaped rudders changed to wedge shaped. At the higher speed achieved moving from tail dragging boats to full surface boats, it was noticed that the older rudders tended to flutter for reasons pointed out in Jay's post. The fluttering vibration issue was solved when some smart fellow put on the first wedge shaped rudder and they have not changed since.
                    The following helps to explain the topic.
                    • 785boats
                      Wet Track Racing
                      • 3423
                      Thanks. Now we know.
                      Paul.
                      • Eodman
                        • 1285
                        Well hell all I want to do is have fun & now Fluid you come up with fluid dynamics and stuff!
                        My Mean Machine is running in the low 40's and it doesn't care thing 1 about the shape of its rudder! Good enough for me!
                        You helped me with the initial setup choices so you can do the school stuff and just pass it on! Thank you thank you very much!
                        We did it with a Bang!
                        Cats Are Where It's At!
