Did you get my PM?
winch for rescue boat question
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Hi Lonewolf
If you used a sailwinch servo on the third channel it would go fully in and out. Just a thought.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
I dug thru my supplies and found a gear reduction motor that i geared deown a bit more and made a spool and housing for a winch assembly... Now to make the enclosure for winch and electronics..........also have to make the basket and attch to boat then figure the cut off limit switch mounting...I hope to make some good progress this weekend...Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
Well ive got a working solution....A few minor details to take care but ready to test.... heres the other challenge... how well will the nihm cells do?? been sitting for about 5 yrs+ got 2 packs to charge and working on 2 others..... sow discharge and charge for a couple days then increase the rates of charge/discharge start low work hi.... and pray.... Did you know you can stuff over 4000 mah into a 3600mah intellect pack.....hmmmmmmm and it was only warm....ya i sit close to them while charging and check regularly..... only hope they hold a charge so far 2 packs look good,,, shall see with a test in recovery boat along shoreline.... keeping a rod and snag device close at hand....lolTwin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
