winch for rescue boat question
  • lonewolf
    • Jul 2007
    • 658
    I have a pvc/pool noodle recovery boat that Diego Boy so nicly donated to me... Ok now here the question... I am useing the 3rd channel of a fs Gtc3 The 3rd channel does not allow a servo to go to neutral.. However I am using the 3rd channel to raise and lower a catch basket... My problem is how to get the winch to stop rotating when it reaches bottom and top. The winch NEEDS to stop at top and bottom. There is enough torque in this thing to rip itself loose or break stuff .
    I could really use some ideas..... on how to control this winch accurately.....Thanks a huge bunch !!!!!!
    OK so lets brainstorm
  • monojeff
    • Nov 2010
    • 2551
    Photos?
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • lonewolf
      • Jul 2007
      • 658
      As of now I am planning on raising and lowering a basket using four lines one to each corner then us a spool to winch the lines, as of now it will keep spooling till unwound then rewind...Hard to see all this going on from across the pond....The winch I am using is a gear motor 6v 150rpm 170 mah... A low voltage motor with a gear reduction....I also have a bunch of small limit switches..... Ive got the parts now how to do.... This thing is super strong and maybe a bit fast. so control is critical
      • lonewolf
        • Jul 2007
        • 658
        not as of yet its a bit of an ordeal to transfer pics from phone to pc...Cant see the pics I want to transfer till I get them on pc so gotta dl all pics to sort them out....
        • lonewolf
          • Jul 2007
          • 658
          will try and get some up tmo
          • Doug Smock
            • 5264
            One way to do it is with a servo, micro switch, two relays and two limit switches.
            What is the voltage of the winch?
            That is what I did here.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • lonewolf
              • Jul 2007
              • 658
              6 volts have some gears to reduce speed just not sure how much... also plan on using a cc bec to control voltage at 4.8
              • lonewolf
                • Jul 2007
                • 658
                how do the relay play in ? have a 20 ans 32 tooth gears but would have to make a gearbox not so easy without a mill had one before i got perm layed off...
                • Doug Smock
                  • 5264
                  Your third channel servo controls a micro switch that energizes, de energizes the coils on the relays. You'd have a up and down relay because you have to reverse the polarity on your winch motor right? The limit switches would be wired in series with the 3rd channel micro switch C NO/ NC & relay coils.
                  Is your third channel set, or can it be set to On/Off. In other words can it be set to operate a servo all the way in one direction, then when you switch it, it operates the servo all the way in the other direction?
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • lonewolf
                    • Jul 2007
                    • 658
                    I emailed the pics to myself hope it works....pick of the boat... Doug any chance you could or would share details ...??? Ive got me some learning to do Thanks guys
                    got the pics here ya go
                    • lonewolf
                      • Jul 2007
                      • 658
                      Third chan is set... hit once goes one way hit again it stops hit again goes other direction till hit button again
                      Now if it was momentary that would be perfect
                      • lonewolf
                        • Jul 2007
                        • 658
                        4 button pushes to go thru whole cycle
                        • lonewolf
                          • Jul 2007
                          • 658
                          I have circuit that uses a servo and micro switch to operate the winch just need to figure out a way to stop it when it hits up and down.....Getting confusing in my brain or just go simple and bust out my seven channel radio but not so fond of that idea here is the circuit
                          • lonewolf
                            • Jul 2007
                            • 658
                            It may be possible to use the trim to control up and down but still need to stop the motor from turning when limit has been reached
                            • lonewolf
                              • Jul 2007
                              • 658
                              Next part of mission.. make the gearbox and spool assembly.... still need to control this beast... after power off still get 2 revolutions.....tmos mission...thank builders
