Has anyone ever used one of these? Apparently you can run the antenna inside the boat and the rage would be the same.
FM Antenna
FM Antenna
Has anyone ever used one of these? Apparently you can run the antenna inside the boat and the rage would be the same.Tags: None
Someone could test it. Place this vertical antenna in the hull then place your boat in your front yard on the ground with stand. Get someone with a cell phone to stay with the boat and you walk down the street with the transmitter and cell phone. Use your steering as you walk and see if there is any difference in distance or glitching with the ways you mount the antenna. It will also give you a better idea of your radio range.
I should do this with all builds. Should not wait until I get it on the water to test it. Had a runaway with one new boat.Last edited by ReddyWatts; 08-26-2008, 01:03 PM.ReddyWatts fleet photo
