FM Antenna
  • SweetAccord
    Speed Passion
    • 1322
    FM Antenna
    Has anyone ever used one of these? Apparently you can run the antenna inside the boat and the rage would be the same.
  • ReddyWatts
    • 1756
    Someone could test it. Place this vertical antenna in the hull then place your boat in your front yard on the ground with stand. Get someone with a cell phone to stay with the boat and you walk down the street with the transmitter and cell phone. Use your steering as you walk and see if there is any difference in distance or glitching with the ways you mount the antenna. It will also give you a better idea of your radio range.
    I should do this with all builds. Should not wait until I get it on the water to test it. Had a runaway with one new boat.
    ReddyWatts fleet photo
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      I tried one and I do not recommend them for boat useage. Loss of signal issues
      Douggie
      • JimClark
        • 5913
        Very fragile wire also
        Billy Graham
        • icelert
          • Dec 2007
          • 103
          Any carbon fiber in the hull would act as a shield and kept the rx from getting an efficient signal. Compare it to the window on a microwave oven. That tiny mesh keeps the microwave frequencies from escaping.
          • SweetAccord
            Speed Passion
            • 1322
            Ok then forget it. Thanks all!
