What's the best long distance radio??
  • DK535
    • Jan 2012
    • 626
    Finishing a build and need a long distance great radio setup for my big mono? Any suggestions?? Not a fan of spektrum and tactic seems to be hit or miss with distance. My Traxxas Rx/Tx from my Spartan worked real well. Suggestions?
  • kevinpratt823
    • Aug 2012
    • 1360
    Many would say Futaba.
    My private off road rc track
    • DK535
      • Jan 2012
      • 626
      Any futaba in particular?
      • KartRacer
        • Aug 2012
        • 355
        Read a test on rc soup or big squid and it showed Futaba at nearly twice the distance of other brands.
        KartRacer ~ Dennis B
        Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
          • 7277
          Why is distance so critical...you won't be able to tell if its coming or going .
          • mtbenjamin77
            • 761
            any futaba 3prka or 4pk-r just be sure to keep the rx dry
            • oscarel
              • Dec 2009
              • 2135
              Flysky GT3B tested to 2 miles, not sure you'd need much more than that.
              • devo
                • Aug 2012
                • 146
                Buy a futaba. I have tactic, spektrum, and futaba radios and I would rate them 1. Futaba (never loses signal as long as you keep it dry) 2. Tactic (rarely loses signal) 3. Spektrum (regularly loses signal) others may have different opinions but I wouldn't have a flysky as I have witnessed 2 major crashes over the receivers failing
                • Chilli
                  • 3067
                  Futaba 3PM. You can a used one for a reasonable price on ebay. Despite some saying you do not need an antenna outside the boat, mount one anyway for maximum range. I'm with devo that the Futaba recievers can glitch if they get wet. Nothing a shot of wd40 and burst of air won't immediately cure.
                  Mike Chirillo
                  www.capitolrcmodelboats.com
                  • iamandrew
                    • 574
                    im still blown away by my crappy GT 2 and GT 3 HK radios, all still working well!
                    • DK535
                      • Jan 2012
                      • 626
                      Wow guys thanks for the input !! I need a glitch free long distance combo for a large 65" mono build and need good range.
                      • DK535
                        • Jan 2012
                        • 626
                        Wanted to avoid a antenna if possible
                        • Chilli
                          • 3067
                          Let me elaborate on the Futaba wet reciever glitching. Then only time I ever had a problem with my Futaba FASST radio is when the boat flooded and I didnt take time to ensure the reciever was dry before the next run.
                          If you want maximum range, the line of sight between the transmitter and receiver must be unobstructed. Anything less and your rolling the dice.
                          Mike Chirillo
                          • LiPo Power
                            DJI Drone Advanced Pilot
                            • 3186
                            2 on that:
                            Canada
                            • jkr
                              FE Addiction
                              • 568
                              There is also UHF signal for extreme ranges.Many people use them for fpv with range <25miles but you need a tx with module.
